Preliminary Datasheet ADP1074 (Analog Devices) - 8
DescriptionIsolated Synchronous Forward Controller with Active Clamp and iCoupler
Pages / Page14 / 8 — ADP1074. Preliminary Technical Data. REGULATORY INFORMATION. Table 2. UL …
File Format / SizePDF / 380 Kb
ADP1074. Preliminary Technical Data. REGULATORY INFORMATION. Table 2. UL (Pending). CSA (Pending). VDE (Pending). CQC (Pending)
ADP1074 Preliminary Technical Data REGULATORY INFORMATION Table 2 UL (Pending) CSA (Pending) VDE (Pending) CQC (Pending)
link to page 9 link to page 13
See Table 5 and the Insulation Lifetime section for details regarding recommended maximum working voltages for specific cross-isolation waveforms and insulation levels.
Table 2. UL (Pending) CSA (Pending) VDE (Pending) CQC (Pending)
Recognized Under UL 1577 Approved under CSA Component Acceptance Certified according to DIN V VDE V Certified by Component Recognition Notice 5A 0884-10 (VDE V 0884-10):2006-122 CQC11-471543-2012, Program1 GB4943.1-2011: Single Protection, 5000 V rms CSA 60950-1-07+A1+A2 and IEC 60950-1, Reinforced insulation, VIORM = Basic insulation at Isolation Voltage second edition, +A1+A2: 849 peak, VIOTM = 8000 V peak 780 V rms (1103 V peak) Basic insulation at 780 V rms (1103 V peak) Reinforced insulation at Reinforced insulation at 390 V rms 389 V rms (552 V peak), (552 V peak) tropical climate, altitude ≤5000 meters IEC 60601-1 Edition 3.1: Basic insulation (1 means of patient protection (1 MOPP)), 490 V rms (686 V peak) Reinforced insulation (2 MOPP), 238 V rms (325 V peak) CSA 61010-1-12 and IEC 61010-1 third edition: Basic insulation at 300 V rms mains, 780 V secondary (1103 V peak) File E214100 File 205078 File 2471900-4880-0001 File (pending) 1 In accordance with UL 1577, each product is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec. 2 In accordance with DIN V VDE V 0884-10, each product is proof tested by applying an insulation test voltage ≥ 1592 V peak for 1 sec (partial discharge detection limit = 5 pC). The * marking branded on the component designates DIN V VDE V 0884-10 approval. Rev. PrB | Page 8 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS TYPICAL APPLICATION CIRCUITS SPECIFICATIONS REGULATORY INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS SIMPLIFIED BLOCK DIAGRAM APPLICATIONS INFORMATION INSULATION LIFETIME OUTLINE DIMENSIONS
