Datasheet AD711 (Analog Devices) - 4
DescriptionPrecision, Low Cost, High Speed, BiFET Op Amp
Pages / Page17 / 4 — AD711. ABSOLUTE MAXIMUM RATINGS1. ORDERING GUIDE. Temperature. Package. …
RevisionE
File Format / SizePDF / 630 Kb
AD711. ABSOLUTE MAXIMUM RATINGS1. ORDERING GUIDE. Temperature. Package. Model. Range. Description. Option*. CAUTION. WARNING!
AD711 ABSOLUTE MAXIMUM RATINGS1 ORDERING GUIDE Temperature Package Model Range Description Option* CAUTION WARNING!
Supply Voltage . ±18 V
Temperature Package Package
Internal Power Dissipation2 . 500 mW
Input Voltage3 . ±18 V *AD711AH –40∞C to +85∞C 8-Pin Metal Can H-08A Output Short Circuit Duration . Indefinite AD711AQ –40∞C to +85∞C 8-Pin Ceramic DIP Q-8 Differential Input Voltage . +VS and –VS *AD711BQ –40∞C to +85∞C 8-Pin Ceramic DIP Q-8 Storage Temperature Range (Q, H) . –65∞C to +150∞C *AD711CH –40∞C to +85∞C 8-Pin Metal Can H-08A Storage Temperature Range (N) . –65∞C to +125∞C AD711JN 0∞C to 70∞C 8-Pin Plastic DIP N-8 Operating Temperature Range AD711JR 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 AD711J/K . 0∞C to +70∞C AD711JR-REEL 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 AD711A/B/C . –40∞C to +85∞C AD711JR-REEL7 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 AD711S/T . –55∞C to +125∞C AD711KN 0∞C to 70∞C 8-Pin Plastic DIP N-8 Lead Temperature Range (Soldering 60 sec) . 300∞C AD711KR 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 AD711KR-REEL 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 NOTES AD711KR-REEL7 0∞C to 70∞C 8-Pin Plastic SOIC RN-8 1Stresses above those listed under “Absolute Maximum Ratings” may cause *AD711SQ/883B –55∞C to +125∞C 8-Pin Ceramic DIP Q-8 permanent damage to the device. This is a stress rating only and functional *AD711TQ/883B –55∞C to +125∞C 8-Pin Ceramic DIP Q-8 operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute *Not for new design, obsolete April 2002 maximum rating conditions for extended periods may affect device reliability. 2Thermal Characteristics: 8-Pin Plastic Package: qJC = 33∞C/Watt; qJA = 100∞C/Watt 8-Pin Cerdip Package: qJC = 22∞C/Watt; qJA = 110∞C/Watt 8-Pin Metal Can Package: qJC = 65∞C/Watt; qJA = 150∞C/Watt 8-Pin SOIC Package: qJC = 43∞C/Watt; qJA = 160∞C/Watt 3For supply voltages less than ±18 V, the absolute maximum input voltage is equal to the supply voltage.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the AD711 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are
ESD SENSITIVE DEVICE
recommended to avoid performance degradation or loss of functionality. REV. E –3– Document Outline FEATURES PRODUCT DESCRIPTION CONNECTION DIAGRAMS PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics OPTIMIZING SETTLING TIME OP AMP SETTLING TIME—A MATHEMATICAL MODEL GUARDING D/A CONVERTER APPLICATIONS NOISE CHARACTERISTICS DRIVING THE ANALOG INPUT OF AN A/D CONVERTER DRIVING A LARGE CAPACITIVE LOAD ACTIVE FILTER APPLICATIONS SECOND ORDER LOW PASS FILTER 9-POLE CHEBYCHEV FILTER OUTLINE DIMENSIONS Revision History
