Datasheet AD743 (Analog Devices) - 3
DescriptionUltralow Noise BiFET Op Amp
Pages / Page13 / 3 — AD743–SPECIFICATIONS (@ 25. C and. 15 V dc, unless otherwise noted.) …
RevisionE
File Format / SizePDF / 301 Kb
AD743–SPECIFICATIONS (@ 25. C and. 15 V dc, unless otherwise noted.) Parameter. Conditions. Min. Typ. Max. Unit
AD743–SPECIFICATIONS (@ 25 C and 15 V dc, unless otherwise noted.) Parameter Conditions Min Typ Max Unit
C and
INPUT OFFSET VOLTAGE1 Initial Offset 0.25 1.0 mV Initial Offset TMIN to TMAX 1.5 mV vs. Temperature TMIN to TMAX 2 µV/°C vs. Supply (PSRR) 12 V to 18 V2 90 96 dB vs. Supply (PSRR) TMIN to TMAX 88 dB INPUT BIAS CURRENT3 Either Input VCM = 0 V 150 400 pA Either Input @ TMAX VCM = 0 V 8.8 nA Either Input VCM = 10 V 250 600 pA Either Input, VS = ± 5 V VCM = 0 V 30 200 pA INPUT OFFSET CURRENT VCM = 0 V 40 150 pA Offset Current @ TMAX VCM = 0 V 2.2 nA FREQUENCY RESPONSE Gain BW, Small Signal G = –1 4.5 MHz Full Power Response VO = 20 V p-p 25 kHz Slew Rate, Unity Gain G = –1 2.8 V/µs Settling Time to 0.01% 6 µs Total Harmonic Distortion4 f = 1 kHz (TPC 16) G = –1 0.0003 % INPUT IMPEDANCE Differential 1 1010储20 Ω储pF Common Mode 3 1011储18 Ω储pF INPUT VOLTAGE RANGE Differential5 ±20 V Common-Mode Voltage +13.3, –10.7 V Over Maximum Operating Range6 –10 +12 V Common-Mode Rejection Ratio VCM = ± 10 V 80 95 dB TMIN to TMAX 78 dB INPUT VOLTAGE NOISE 0.1 Hz to 10 Hz 0.38 µV p-p f = 10 Hz 5.5 nV/√Hz f = 100 Hz 3.6 nV/√Hz f = 1 kHz 3.2 5.0 nV/√Hz f = 10 kHz 2.9 4.0 nV/√Hz INPUT CURRENT NOISE f = 1 kHz 6.9 fA/√Hz OPEN-LOOP GAIN VO = ± 10 V, RLOAD ≥ 2 kΩ 1000 4000 V/mV TMIN to TMAX 800 V/mV RLOAD = 600 Ω 1200 V/mV OUTPUT CHARACTERISTICS Voltage RLOAD ≥ 600 Ω +13, –12 V RLOAD ≥ 600 Ω +13.6, –12.6 V TMIN to TMAX +12, –10 V RLOAD ≥ 2 kΩ ±12 +13.8, –13.1 V Current Short Circuit 20 40 mA POWER SUPPLY Rated Performance ±15 V Operating Range ±4.8 ±18 V Quiescent Current 8.1 10.0 mA TRANSISTOR COUNT No. of Transistors 50 NOTES 1Input offset voltage specifications are guaranteed after five minutes of operation at T A = 25°C. 2Test conditions: +VS = 15 V, –VS = 12 V to 18 V; and +VS = 12 V to 18 V, –VS = 15 V. 3Bias current specifications are guaranteed maximum at either input after 5 minutes of operation at T A = 25°C. For higher temperature, the current doubles every 10°C. 4Gain = –1, RL = 2 kΩ, CL = 10 pF. 5Defined as voltage between inputs, such that neither exceeds ±10 V from common. 6The AD743 does not exhibit an output phase reversal when the negative common-mode limit is exceeded. All min and max specifications are guaranteed. Specifications subject to change without notice. –2– REV. E Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS CONNECTION DIAGRAMS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD SUSCEPTIBILITY ORDERING GUIDE Typical Performance Characteristics OP AMP PERFORMANCE: JFET VS. BIPOLAR DESIGNING CIRCUITS FOR LOW NOISE LOW NOISE CHARGE AMPLIFIERS HOW CHIP PACKAGE TYPE AND POWER DISSIPATION AFFECT INPUT BIAS CURRENT REDUCED POWER SUPPLY OPERATION FOR LOWER IB AN INPUT IMPEDANCE COMPENSATED, SALLEN-KEY FILTER TWO HIGH PERFORMANCE ACCELEROMETER AMPLIFIERS LOW NOISE HYDROPHONE AMPLIFIER BALANCING SOURCE IMPEDANCES OUTLINE DIMENSIONS Revision History
