Datasheet AD745 (Analog Devices) - 5
DescriptionUltralow Noise, High Speed, BiFET Op Amp
Pages / Page13 / 5 — AD745 –Typical Performance Characteristics (@ + 25. C, VS =. 15 V, unless …
RevisionD
File Format / SizePDF / 373 Kb
AD745 –Typical Performance Characteristics (@ + 25. C, VS =. 15 V, unless otherwise noted.). RLOAD = 10k. p-p. – 15. – 25. +VIN
AD745 –Typical Performance Characteristics (@ + 25 C, VS = 15 V, unless otherwise noted.) RLOAD = 10k p-p – 15 – 25 +VIN
AD745 –Typical Performance Characteristics (@ + 25 C, VS = 15 V, unless otherwise noted.) 20 20 35 RLOAD = 10k RLOAD = 10k 30 p-p V V – 15 V – 15 – 25 +VIN POSITIVE SWING SWING SUPPLY SWING 20 GE 10 GE 10 A GE T A T A L L T 15 O NEGATIVE L O –V O IN SUPPLY 10 5 5 INPUT V INPUT V OUTPUT V 5 0 0 0 0 5 10 15 20 0 5 10 15 20 10 100 1k 10k SUPPLY VOLTAGE VOLTS SUPPLY VOLTAGE VOLTS LOAD RESISTANCE –
TPC 1. Input Voltage Swing vs. TPC 2. Output Voltage Swing vs. TPC 3. Output Voltage Swing vs. Supply Voltage Supply Voltage Load Resistance
12 200 10–6 100 10–7 mA 9 Amps 10 – 10–8 ANCE 6 10–9 1 CLOSED LOOP GAIN = –5 10–10 3 UIESCENT CURRENT OUTPUT IMPED 0.1 Q INPUT BIAS CURRENT 10–11 0 0.01 10–12 0 5 10 15 20 10k 100k 1M 10M 100M –60 –40 –20 0 20 40 60 80 100 120 140 SUPPLY VOLTAGE VOLTS TEMPERATURE – FREQUENCY – Hz C
TPC 4. Quiescent Current vs. TPC 5. Input Bias Current vs. TPC 6. Output Impedance vs. Supply Voltage Temperature Frequency
300 10–6 28 26 10–7 MHz pA Amps 200 24 10–8 ODUCT 22 10–9 20 100 WIDTH PR 10–10 AND 18 INPUT BIAS CURRENT INPUT BIAS CURRENT 10–11 16 GAIN B 0 –12 –9 –6 –3 0 3 6 9 12 10–12 14 –60 –40 –20 0 20 40 60 80 100 120 140 –60 –40 –20 0 20 40 60 80 100 120 140 COMMON-MODE VOLTAGE – V TEMPERATURE – C TEMPERATURE – C
TPC 7. Input Bias Current vs. TPC 8. Short Circuit Current Limit vs. TPC 9. Gain Bandwidth Product vs. Common-Mode Voltage Temperature Temperature –4– REV. D
