Datasheet AD818 (Analog Devices) - 6
Description | Low Cost, Low Power Video Op Amp |
Pages / Page | 16 / 6 — Typical Performance Characteristics–AD818. V) 15. L = 500. –VCM. RL = … |
Revision | D |
File Format / Size | PDF / 630 Kb |
Typical Performance Characteristics–AD818. V) 15. L = 500. –VCM. RL = 150. OUTPUT VOLTAGE SWING (. INPUT COMMON-MODE RANGE (
Typical Performance Characteristics–AD818 20 20 V)
ⴞ
15 V) 15
ⴞ
R +V L = 500
CM 10 10 –VCM RL = 150
5 5 OUTPUT VOLTAGE SWING ( INPUT COMMON-MODE RANGE ( 0 0 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE (
ⴞ
V) SUPPLY VOLTAGE (
ⴞ
V)
TPC 1. Common-Mode Voltage Range vs. Supply TPC 4. Output Voltage Swing vs. Supply
30 8.0 25 7.5 VS =
ⴞ
15V 20 +85
ⴗ
C +25
ⴗ
C 15 7.0 –40
ⴗ
C 10 VS =
ⴞ
5V 6.5 OUTPUT VOLTAGE SWING (V p-p) 5 QUIESCENT SUPPLY CURRENT (mA) 0 6.0 10 100 1k 10k 0 5 10 15 20 LOAD RESISTANCE (
) SUPPLY VOLTAGE (
ⴞ
V)
TPC 2. Output Voltage Swing vs. Load Resistance TPC 5. Quiescent Supply Current vs. Supply Voltage
600 100 )
500 10 s)
400 1 SLEW RATE (V/ 300 0.1 CLOSED-LOOP OUTPUT IMPEDANCE ( 200 0.01 0 5 10 15 20 1k 10k 100k 1M 10M 100M SUPPLY VOLTAGE (
ⴞ
V) FREQUENCY (Hz)
TPC 3. Slew Rate vs. Supply Voltage TPC 6. Closed-Loop Output Impedance vs. Frequency REV. D –5– Document Outline Untitled
