Datasheet LTC2358-18 (Analog Devices) - 8
DescriptionBuffered Octal, 18-Bit, 200ksps/Ch Differential ±10.24V ADC with 30VP-P Common Mode Range
Pages / Page38 / 8 — ADC TIMING CHARACTERISTICS Note 1:. Note 10:. Note 11:. Note 2:. Note …
File Format / SizePDF / 2.3 Mb
ADC TIMING CHARACTERISTICS Note 1:. Note 10:. Note 11:. Note 2:. Note 12:. Note 3:. Note 4:. Note 5:. Note 13:. Note 6:. Note 14:. Note 7:
ADC TIMING CHARACTERISTICS Note 1: Note 10: Note 11: Note 2: Note 12: Note 3: Note 4: Note 5: Note 13: Note 6: Note 14: Note 7:
LTC2358-18
Note 10:
Integral nonlinearity is defined as the deviation of a code from a may cause permanent damage to the device. Exposure to any Absolute straight line passing through the actual endpoints of the transfer curve. Maximum Rating condition for extended periods may affect device The deviation is measured from the center of the quantization band. reliability and lifetime.
Note 11:
Guaranteed by design, not subject to test.
Note 2:
All voltage values are with respect to GND.
Note 12:
For bipolar SoftSpan ranges 7, 6, 3, and 2, zero-scale error
Note 3:
VDDLBYP is the output of an internal voltage regulator, and should is the offset voltage measured from –0.5LSB when the output code only be connected to a 2.2μF ceramic capacitor to bypass the pin to GND, flickers between 00 0000 0000 0000 0000 and 11 1111 1111 1111 1111. as described in the Pin Functions section. Do not connect this pin to any Full-scale error for these SoftSpan ranges is the worst-case deviation of external circuitry. the first and last code transitions from ideal and includes the effect of
Note 4:
When these pin voltages are taken below V offset error. For unipolar SoftSpan ranges 5, 4, and 1, zero-scale error is EE or above VCC, they will be clamped by internal diodes. This product can handle input currents the offset voltage measured from 0.5LSB when the output code flickers of up to 100mA below V between 00 0000 0000 0000 0000 and 00 0000 0000 0000 0001. Full- EE or above VCC without latch-up.
Note 5:
When these pin voltages are taken below GND or above V scale error for these SoftSpan ranges is the worst-case deviation of the DD or OV last code transition from ideal and includes the effect of offset error. DD, they will be clamped by internal diodes. This product can handle currents of up to 100mA below GND or above V
Note 13:
All specifications in dB are referred to a full-scale input in the DD or OVDD without latch- up. relevant SoftSpan input range, except for crosstalk, which is referred to
Note 6:
–16.5V ≤ V the crosstalk injection signal amplitude. EE ≤ 0V, 7.5V ≤ VCC ≤ 38V, 10V ≤ (VCC – VEE) ≤ 38V, V
Note 14:
Temperature coefficient is calculated by dividing the maximum DD = 5V, unless otherwise specified.
Note 7:
Recommended operating conditions. change in output voltage by the specified temperature range.
Note 8:
Exceeding these limits on any channel may corrupt conversion
Note 15:
When REFBUF is overdriven, the internal reference buffer must results on other channels. Driving an analog input above V be disabled by setting REFIN = 0V. CC on any channel up to 10mA will not affect conversion results on other channels.
Note 16:
IREFBUF varies proportionally with sample rate and the number of Driving an analog input below V active channels. EE may corrupt conversion results on other channels. Refer to Applications Information section for further details.
Note 17:
Analog input buffer supply currents from IVCC and IVEE are Refer to Absolute Maximum Ratings section for pin voltage limits related reduced outside the acquisition period. Refer to nap mode in Applications to device reliability. Information section.
Note 9:
VCC = 15V, VEE = –15V, VDD = 5V, OVDD = 2.5V, fSMPL = 200ksps,
Note 18:
Parameter tested and guaranteed at OVDD = 1.71V, OVDD = 2.5V, internal reference and buffer, true bipolar input signal drive in bipolar and OVDD = 5.25V. SoftSpan ranges, unipolar signal drive in unipolar SoftSpan ranges, unless
Note 19:
A tSCKI period of 10ns minimum allows a shift clock frequency of otherwise specified. up to 100MHz for rising edge capture.
Note 20:
VICM = 1.2V, VID = 350mV for LVDS differential input pairs.
CMOS Timings
0.8 • OVDD tWIDTH 0.2 • OVDD t tDELAY 50% 50% DELAY 235818 F01 0.8 • OVDD 0.8 • OVDD 0.2 • OVDD 0.2 • OVDD
LVDS Timings (Differential)
+200mV tWIDTH –200mV t tDELAY 0V 0V DELAY 235818 F01b +200mV +200mV –200mV –200mV
Figure 1. Voltage Levels for Timing Specifications
235818f 8 For more information www.linear.com/LTC2358-18 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Reference Buffer Characteristics Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Configuration Tables Functional Block Diagram Timing Diagram Applications Information Board Layout Package Description Typical Application Related Parts
