Datasheet AD823A (Analog Devices) - 7
Description17 MHz, Rail-to-Rail FET Input Dual Amplifier
Pages / Page21 / 7 — AD823A. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. …
RevisionB
File Format / SizePDF / 580 Kb
AD823A. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter Rating. Table 5. Thermal Resistance
AD823A Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating Table 5 Thermal Resistance
link to page 7 link to page 7
AD823A Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltage 36 V soldered in a circuit board for surface-mount packages. Power Dissipation See Figure 4 The specification is for the device in free air. Input Voltage (Common Mode) ±VS ± 0.7 V Differential Input Voltage ±VS
Output Short-Circuit Duration See Figure 4
Package Type θJA Unit
Storage Temperature Range −65°C to +125°C 8-Lead SOIC_N 120 °C/W Operating Temperature Range −40°C to +85°C 8-Lead MSOP 133 °C/W Lead Temperature (Soldering, 10 sec) 300°C ESD Ratings (Human Body Model) 4500 V
2.0 TJ = 150°C
ESD Ratings (Charged Device Model) 1250 V
) (W N IO 1.5 T
Stresses above those listed under Absolute Maximum Ratings
PA 8-LEAD SOIC
may cause permanent damage to the device. This is a stress
ISSI
rating only; functional operation of the device at these or any
D 1.0 ER
other conditions above those indicated in the operational
W 8-LEAD MSOP
section of this specification is not implied. Exposure to absolute
PO M
maximum rating conditions for extended periods may affect
MU 0.5 XI
device reliability.
MA
Use the part with caution at the 30 V supply as excessive output
0
current may overheat and damage the part. 4
–45 –35 –25 –15 –5 5 15 25 35 45 55 65 75 85
-00 9
AMBIENT TEMPERATURE (°C)
43 09 Figure 4. Maximum Power Dissipation vs. Temperature
ESD CAUTION
Rev. B | Page 6 of 20 Document Outline Features Applications General Description Connection Diagram Revision History Specifications 5 V Operation 3.3 V Operation ±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Impedance Applications Information Input Characteristics Output Characteristics Wideband Photodiode Preamp Active Filter Maximizing Performance Through Proper Layout Outline Dimensions Ordering Guide
