Data SheetADA4891-1/ADA4891-2/ADA4891-3/ADA4891-4REVISION HISTORY 9/15—Rev. E to Rev. F7/10—Rev. A to Rev. B Changes to Features .. 1 Added ADA4891-3 and ADA4891-4 ... Universal Moved Revision History Section ... 3 Added 14-Lead SOIC and 14-Lead TSSOP Packages ... Universal Changes to Table 1 .. 4 Deleted Figure 4; Renumbered Figures Sequential y ... 1 Changes to Table 2 .. 5 Changes to Features Section and General Description Section .. 1 Changes to Figure 7 and Figure 10 ... 8 Added Figure 4 and Figure 5 ... 1 Changes to Figure 15 and Figure 18 ... 9 Changes to Table 1 .. 3 Changes to Figure 19, Figure 21, and Figure 22 .. 10 Changes to Table 2 .. 4 Changes to Figure 25 and Figure 29 ... 11 Changes to Maximum Power Dissipation Section Changes to Figure 32, Figure 33, and Figure 36 .. 12 and Figure 6 ... 6 Change to Figure 47 .. 14 Added Table 4; Renumbered Tables Sequentially ... 6 Changes to Ordering Guide ... 24 Deleted Figure 11 .. 6 Change to Automotive Products Section ... 24 Changes to Typical Performance Characteristics Section ... 7 Deleted Figure 12 .. 7 3/13—Rev. D to Rev. E Changes to Wideband, Noninverting Gain Operation Section, Change to Features Section .. 1 Wideband, Inverting Gain Operation Section, and Table 5 .. 15 Changes to DC Performance Parameter, Table 1 .. 3 Added Table 6 .. 16 Changes to DC Performance Parameter, Table 2 .. 4 Changes to Figure 52 .. 16 Changes to Ordering Guide ... 23 Added Figure 53 .. 16 Changes to Automotive Products Section ... 23 Changed Layout of Driving Capacitive Loads Section .. 17 Added Disable Feature (ADA4891-3 Only) Section 3/12—Rev. C to Rev. D and Single-Supply Operation Section .. 18 Added ADA4891-1W and ADA4891-2W .. Universal Added Multiplexer Section .. 19 Changes to Features Section and Applications Section ... 1 Updated Outline Dimensions.. 21 Changes to Input Offset Voltage, Input Bias Current, and Open- Changes to Ordering Guide ... 23 Loop Gain Parameters, Table 1 .. 4 Changes to Input Offset Voltage, Input Bias Current, and Open- 6/10—Rev. 0 to Rev. A Loop Gain Parameters, Table 2 .. 5 Changes to Figure 26 .. 9 Changes to Ordering Guide ... 23 Changes to Figure 33 and Figure 34 ... 10 Added Automotive Products Section ... 23 Updated Outline Dimensions.. 18 Changes to Ordering Guide ... 18 9/10—Rev. B to Rev. C Changes to Figure 23 and Figure 24 ... 9 2/10—Revision 0: Initial Version Rev. F | Page 3 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS 5 V OPERATION 3 V OPERATION ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION USING THE ADA4891-1/ADA4891-2/ADA4891-3/ ADA4891-4 WIDEBAND, NONINVERTING GAIN OPERATION WIDEBAND, INVERTING GAIN OPERATION RECOMMENDED VALUES EFFECT OF RF ON 0.1 dB GAIN FLATNESS DRIVING CAPACITIVE LOADS TERMINATING UNUSED AMPLIFIERS DISABLE FEATURE (ADA4891-3 ONLY) SINGLE-SUPPLY OPERATION VIDEO RECONSTRUCTION FILTER MULTIPLEXER LAYOUT, GROUNDING, AND BYPASSING POWER SUPPLY BYPASSING GROUNDING INPUT AND OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING LEAKAGE CURRENTS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
