link to page 10 link to page 10 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 NCS20071, NCV20071, NCS20072, NCV20072, NCS20074, NCV20074ELECTRICAL CHARACTERISTICS AT VS = 10 V TA = 25°C; RL ≥ 10 kW; VCM = VOUT = mid−supply unless otherwise noted. All limits are guaranteed by testing or statistical analysis. Boldface limits apply over the specified temperature range, TA = −40°C to 125°C. (Notes 17, 18) ParameterSymbolConditionsMinTypMaxUnitNOISE CHARACTERISTICS Total Harmonic Distortion plus Noise THD+N VIN = 7.5 Vpp, f = 1 kHz, Av = 1 0.004 % f = 1 kHz 30 Input Referred Voltage Noise en nV/√Hz f = 10 kHz 20 Input Referred Current Noise in f = 1 kHz 90 fA/√Hz SUPPLY CHARACTERISTICS 114 135 Power Supply Rejection Ratio PSRR No Load dB 100 430 645 NCx20071 No load 785 Power Supply Quiescent Current IDD mA 416 540 NCx20072, NCx20074 Per channel, no load 640 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 17. Refer to ABSOLUTE MAXIMUM RATINGS and APPLICATION INFORMATION for Safe Operating Area. 18. Performance guaranteed over the indicated operating temperature range by design and/or characterization. 19. Power dissipation must be limited to prevent junction temperature from exceeding 150°C. See Absolute Maximum Ratings for more infor- mation. ELECTRICAL CHARACTERISTICS AT VS = 36 V TA = 25°C; RL ≥ 10 kW; VCM = VOUT = mid−supply unless otherwise noted. All limits are guaranteed by testing or statistical analysis. Boldface limits apply over the specified temperature range, TA = −40°C to 125°C. (Notes 20, 21) ParameterSymbolConditionsMinTypMaxUnitINPUT CHARACTERISTICS 1.3 ±3.5 mV NCx20071 + 4.5mV Input Offset Voltage VOS 1.3 ±3 mV NCx20072, NCx20074 + 4mV Offset Voltage Drift DVOS/DT TA = 25°C to 125°C 2 mV/°C 5 200 Input Bias Current (Note 21) IIB NCx20071, NCx20072 2000 pA NCx20074 1500 2 75 NCx20071, NCx20072 1000 Input Offset Current (Note 21) IOS pA 2 75 NCx20074 200 NCx20072 100 Channel Separation XTLK DC dB NCx20074 115 Differential Input Resistance RID 5 GW Common Mode Input Resistance RIN 5 GW Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 20. Refer to ABSOLUTE MAXIMUM RATINGS and APPLICATION INFORMATION for Safe Operating Area. 21. Performance guaranteed over the indicated operating temperature range by design and/or characterization. 22. Power dissipation must be limited to prevent junction temperature from exceeding 150°C. See Absolute Maximum Ratings for more infor- mation. www.onsemi.com10
