Datasheet MAX6138 (Maxim) - 6
Manufacturer | Maxim |
Description | 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages |
Pages / Page | 13 / 6 — 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown … |
File Format / Size | PDF / 340 Kb |
0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages. Typical Operating Characteristics
0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages Typical Operating Characteristics
(IR = 100µA, TA = +25°C, unless otherwise noted.)
REVERSE CHARACTERISTICS AND MAX6138_12 MAX6138_25 MINIMUM OPERATING CURRENT TEMPERATURE DRIFT TEMPERATURE DRIFT
6 1.2215 2.5015 MAX6138_50
MAX6138
2.5010 5 MAX6138 toc01 MAX6138 toc02 MAX6138 toc03 MAX6138_41 1.2210 2.5005 4 MAX6138_30 2.5000 3 1.2205 MAX6138_25 2.4995 MAX6138_20 2 REVERSE VOLTAGE (V) REVERSE VOLTAGE (V) REVERSE VOLTAGE (V) 2.4990 MAX6138_12 1.2200 1 2.4895 3 TYPICAL PARTS 3 TYPICAL PARTS 0 1.2195 2.4890 0 20 40 60 80 100 -40 -20 0 20 40 60 80 -40 -20 0 20 40 60 80 REVERSE CURRENT (µA) TEMPERATURE (°C) TEMPERATURE (°C)
MAX6138_50 MAX6138_12 TEMPERATURE DRIFT REVERSE VOLTAGE vs. ISHUNT
5.0 5.003 4.5 5.002 MAX6138 toc04 4.0 TA = +85°C MAX61438 toc05 3.5 5.001 3.0 5.000 TA = +25°C 2.5 4.999 2.0 REVERSE VOLTAGE (V) 1.5 4.998 TA = -40°C REVERSE VOLTAGE CHANGE (mV) 1.0 4.997 0.5 3 TYPICAL PARTS 4.996 0 -40 -20 0 20 40 60 80 0 5 10 15 20 TEMPERATURE (°C) ISHUNT (mA)
6 _______________________________________________________________________________________
