Datasheet ATtiny13A. Appendix B. Specification at 125°C (Microchip) - 4
ManufacturerMicrochip
Description8-bit AVR Microcontroller with 1K Bytes In-System Programmable Flash
Pages / Page38 / 4 — 1.4. System and Reset Characteristics. 1.4.1. Enhanced Power-On Reset. …
1.4. System and Reset Characteristics. 1.4.1. Enhanced Power-On Reset. Table 1-3. Symbol. Parameter. Min. Typ. Max. Units. 1.5
1.4 System and Reset Characteristics 1.4.1 Enhanced Power-On Reset Table 1-3 Symbol Parameter Min Typ Max Units 1.5
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
1.4 System and Reset Characteristics 1.4.1 Enhanced Power-On Reset Table 1-3.
Characteristics of Enhanced Power-On Reset. T = -40 to +125°C A
(1)
Typ
(1)
Max
(1)
Units
VPOR Release threshold of power-on reset (2) 1.1 1.4 1.7 V VPOA Activation threshold of power-on reset (3) 0.6 1.3 1.7 V SRON Power-On Slope Rate 0.01 V/ms Note: 1. Values are guidelines only. 2. Threshold where device is released from reset when voltage is rising. 3. The Power-on Reset will not work unless the supply voltage has been below VPOA.
1.5 ADC Characteristics Table 1-4.
ADC Characteristics, Single Ended Channels. T = -40°C to +125°C A
Symbol Parameter Condition Min Typ Max Units
Resolution 10 Bits VREF = 4V, VCC = 4V, 3 LSB ADC clock = 200 kHz V = 4V, V = 4V, REF CC 4 LSB Absolute accuracy ADC clock = 1 MHz (Including INL, DNL, and V = 4V, V = 4V, REF CC Quantization, Gain and Offset ADC clock = 200 kHz, 2.5 LSB Errors) Noise Reduction Mode V = 4V, V = 4V, REF CC ADC clock = 1 MHz, 3.5 LSB Noise Reduction Mode Integral Non-Linearity (INL) V (Accuracy after Offset and REF = 4V, VCC = 4V, 1 LSB ADC clock = 200 kHz Gain Calibration) Differential Non-linearity V = 4V, V = 4V, REF CC 0.5 LSB (DNL) ADC clock = 200 kHz V Gain Error REF = 4V, VCC = 4V, 3.5 LSB ADC clock = 200 kHz V = 4V, V = 4V, Offset Error REF CC 2.5 LSB ADC clock = 200 kHz Conversion Time Free Running Conversion 13 260 µs Clock Frequency 50 1000 kHz VIN Input Voltage GND VREF V Input Bandwidth 38.5 kHz VINT Internal Voltage Reference 1.0 1.1 1.2 V RAIN Analog Input Resistance 100 MΩ
4 ATtiny13A
8126F-Appendix B–AVR–05/12 Document Outline Appendix B – ATtiny13A Specification at 125°C 1. Electrical Characteristics 1.1 Absolute Maximum Ratings* 1.2 DC Characteristics 1.3 Clock Characteristics 1.3.1 Accuracy of Calibrated Internal Oscillator 1.4 System and Reset Characteristics 1.4.1 Enhanced Power-On Reset 1.5 ADC Characteristics 1.6 Analog Comparator Characteristics 1.7 Serial Programming Characteristics 2. Typical Characteristics 2.1 Current Consumption in Active Mode 2.2 Current Consumption in Idle Mode 2.3 Current Consumption in Power-down Mode 2.4 Current Consumption of Peripheral Units 2.5 Pull-up Resistors 2.6 Output Driver Strength (Low Power Pins) 2.7 Output Driver Strength (Regular Pins) 2.8 Input Thresholds and Hysteresis (for I/O Ports) 2.9 BOD, Bandgap and Reset 2.10 Internal Oscillator Speed 3. Ordering Information 4. Revision History
