Datasheet ATtiny4, ATtiny5, ATtiny9, ATiny10. Summary Datasheet (Microchip) - 2
Manufacturer | Microchip |
Description | Atmel 8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash |
Pages / Page | 17 / 2 — –. External. and. Internal. Interrupt. Sources. –. Low. Power. Idle,. … |
File Format / Size | PDF / 341 Kb |
–. External. and. Internal. Interrupt. Sources. –. Low. Power. Idle,. ADC. Noise. Reduction,. and. Power-down. Modes. –. Enhanced. Power-on. Reset. Circuit. –
– External and Internal Interrupt Sources – Low Power Idle, ADC Noise Reduction, and Power-down Modes – Enhanced Power-on Reset Circuit – Programmable Supply Voltage Level Monitor with Interrupt and Reset – Internal Calibrated Oscillator • I/O and Packages – Four Programmable I/O Lines – 6-pin SOT and 8-pad UDFN • Operating Voltage: – 1.8 - 5.5V • Programming Voltage: – 5V • Speed Grade: – 0 - 4 MHz @ 1.8 - 5.5V – 0 - 8 MHz @ 2.7 - 5.5V – 0 - 12 MHz @ 4.5 - 5.5V • Industrial and Extended Temperature Ranges • Low Power Consumption – Active Mode: • 200μA at 1MHz and 1.8V Idle Mode: • 25μA at 1MHz and 1.8V – Power-down Mode: • <0.1μA at 1.8V Atmel ATtiny4 / ATtiny5 / ATtiny9 / ATiny10 [DATASHEET] 2 Atmel-8127H-ATiny4/ ATiny5 /ATiny9/ ATiny10_Datasheet_Summary-11/2016 Document Outline Introduction Feature Table of Contents 1. Pin Configurations 1.1. Pin Descriptions 1.1.1. VCC 1.1.2. GND 1.1.3. Port B (PB[3:0]) 1.1.4. RESET 2. Ordering Information 2.1. ATtiny4 2.2. ATtiny5 2.3. ATtiny9 2.4. ATtiny10 3. Overview 3.1. Block Diagram 3.1.1. Description 3.2. Comparison of ATtiny4, ATtiny5, ATtiny9 and ATtiny10 4. General Information 4.1. Resources 4.2. Data Retention 4.3. About Code Examples 4.4. Capacitive Touch Sensing 4.4.1. QTouch Library 5. Packaging Information 5.1. 6ST1 5.2. 8MA4 6. Errata 6.1. ATtiny4 6.1.1. Rev. E 6.1.2. Rev. D 6.1.3. Rev. A – C 6.2. ATtiny5 6.2.1. Rev. E 6.2.2. Rev. D 6.2.3. Rev. A – C 6.3. ATtiny9 6.3.1. Rev. E 6.3.2. Rev. D 6.3.3. Rev. A – C 6.4. ATtiny10 6.4.1. Rev. E 6.4.2. Rev. C – D 6.4.3. Rev. A – B
