Datasheet LT1719 (Analog Devices) - 4
Description4.5ns Single/Dual Supply 3V/5V Comparator with Rail-to-Rail Output
Pages / Page22 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 220 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1719
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 1V, VSHDN = 0.5V, VOVERDRIVE = 20mV, COUT = 10pF and for the LT1719S8 VCC = +VS = 5V and VEE = –5V, for the LT1719S6 V+ = 5V, V– = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IS Positive Output Stage Supply Current + VS = VCC = 5V, VEE = –5V l 4.2 8 mA (LT1719S8 Only) VS = VCC = 3V, VEE = 0V l 3.3 6 mA I+ Supply Current (LT1719S6) V+ = 5V l 4.6 9 mA V+ = 3V l 4.2 7 mA ISHDN5 Shutdown Pin Current +VS or V+ = 5V l –300 –110 –30 μA ISHDN3 Shutdown Pin Current +VS or V+ = 3V l –200 –80 –20 μA ICCS Disabled Supply Currents (LT1719S8) + VS = 6V, VCC = 5V, VEE = –5V l 0.2 30 μA ISS (LT1719S8) VSHDN = +VS – 0.5V l 7 50 μA IEES (LT1719S8) l –30 –0.2 μA I+S (LT1719S6) V+ = 6V, VSHDN = +VS – 0.5V l 7 80 μA ICCSO (LT1719S8) + VS = 6V, VCC = 5V, VEE = –5V l 0.1 20 μA ISSO (LT1719S8) Shutdown Pin Open l 0.1 20 μA I l –20 0.1 μA EEO (LT1719S8) I+O (LT1719S6) V+ = 6V, Shutdown Pin Open l 0.2 40 μA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings VEE = – 5.5V to VEE = 0V divided by 5.5V, or the change in offset voltage may cause permanent damage to the device. Exposure to any Absolute from VCC = +VS = 2.7V to VCC = +VS = 6V (with VEE = 0V) divided by 3.3V. Maximum Rating condition for extended periods may affect device
Note 7:
The LT1719S6 power supply rejection ratio is measured with reliability and lifetime. VCM = 1V and is defi ned as the change in offset voltage measured from
Note 2:
If one input is within these common mode limits, the other input V+ = 2.7V to V+ = 6V, divided by 3.3V. can go outside the common mode limits and the output will be valid.
Note 8:
Because of internal hysteresis, there is no small-signal region in
Note 3:
The LT1719 comparator includes internal hysteresis. The trip which to measure gain. Proper operation of internal circuity is ensured by points are the input voltage needed to change the output state in each measuring VOH and VOL with only 10mV of overdrive. direction. The offset voltage is defi ned as the average of V + – TRIP and VTRIP ,
Note 9:
Propagation delay measurements made with 100mV steps. while the hysteresis voltage is the difference of these two. Overdrive is measured relative to V ± TRIP .
Note 4:
The LT1719S8 common mode rejection ratio is measured with
Note 10:
tPD cannot be measured in automatic handling equipment with VCC = 5V, VEE = –5V and is defi ned as the change in offset voltage measured low values of overdrive. The LT1719 is 100% tested with a 100mV step from VCM = –5.1V to VCM = 3.8V, divided by 8.9V. and 20mV overdrive. Correlation tests have shown that tPD limits can be
Note 5:
The LT1719S6 common mode rejection ratio is measured with guaranteed with this test, if additional DC tests are performed to guarantee V+ = 5V and is defi ned as the change in offset voltage measured from that all internal bias conditions are correct. VCM = –0.1V to VCM = 3.8V, divided by 3.9V.
Note 11:
Propagation Delay Skew is defi ned as:
Note 6:
The LT1719S8 power supply rejection ratio is measured with tSKEW = |tPDLH – tPDHL| VCM = 1V and is defi ned as the worst of: the change in offset voltage from 1719fa 4
