Datasheet LTC1042 (Analog Devices) - 3
DescriptionWindow Comparator
Pages / Page8 / 3 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 121 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LTC1042
C. SYMBOL PARAMETER TEST CONDITIONS MIN TYP MAX UNITS
REXT External Timing Resistor Resistor connected between V + ● 100 10,000 kΩ and OSC Pin fS Sampling Frequency V+ = 5V, TA = 25°C 5 Hz REXT =1MΩ, CEXT = 0.1µF
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
Width error = (VU –VL – 2 • WIDTH/2) (where VU = upper band of a device may be impaired. limit and VL = lower band limit).
Note 2:
Applies over input voltage range limit and includes gain
Note 5:
RIN is guaranteed by design and is not tested. RIN = 1/(fS x 66pF). uncertainty.
Note 6:
Average supply current = TD • lS(ON) • fS + (1 –TD fS) IS(OFF).
Note 3:
Center error = [(VU +VL)/2 – CENTER] (where VU = upper band
Note 7:
Response time is set by an internal oscillator and is independent limit and VL = lower band limit). of overdrive voltage. TD is guaranteed by correlation test and is not directly measured.
W U TYPICAL PERFOR A CE CHARACTERISTICS Normalized Sampling Frequency I vs V+, Temperature S(ON) vs V+ Sampling Rate vs REXT CEXT
20 2.2 103 R = 1M, C = 0.1µF 18 2.0 CEXT = 1000pF 16 1.8 102 14 TA = 125°C CEXT = 0.01µF (Hz) 12 °C) 25 S °C 1.6 (mA) 10 1.4 10 –55°C AT 5V, 25 I S(ON) 8 S (f 1.2 CEXT = 0.1µF 6 TA = 25°C SAMPLE RATE, f 1.0 1 4 125°C C C EXT = 0.05µF EXT = 1µF 2 NORMALIZED SAMPLING FREQUENCY 0.8 TA = –55°C 0 0.6 0.1 2 4 6 8 10 12 14 16 0 2 4 6 8 10 12 14 16 100k 1M 10M SUPPLY VOLTAGE, V+ (V) SUPPLY VOLTAGE, V+ (V) REXT (Ω) LTC1042 • TPC01 LTC1042 • TPC02 LTC1042 • TPC03
Response Time vs Supply Voltage Response Time vs Temperature RIN vs Sampling Frequency
110 130 1011 T V+ = 5V A = 25°C 120 • 66pF) 100 S 110 s) s) (1/F 1010 µ µ ( IN D 90 D 100 90 ) 80 (Ω 109 80 70 70 RESPONSE TIME, t RESPONSE TIME, t 60 108 60 50 50 40 AVERAGE INPUT RESISTANCE, R 107 2 4 6 8 10 12 14 16 –50 –25 0 25 50 75 100 125 1 102 104 103 10 SUPPLY VOLTAGE, V+ (V) AMBIENT TEMPERATURE, TA (°C) SAMPLING FREQUENCY, fS (Hz) LTC1042 • TPC04 LTC1042 • TPC05 LTC1042 • TPC06 1042fa 3
