LTC1443/LTC1444/LTC1445 Ultralow Power Quad Comparators with Reference FeaTuresDescripTion n Ultralow Quiescent Current: 8.5µA Max The LTC®1443/LTC1444/LTC1445 are ultralow power quad n Reference Output Drives 0.01µF Capacitor comparators with a built-in reference. The comparators n Adjustable Hysteresis (LTC1444/LTC1445) feature less than 8.5µA supply current over temperature, n Wide Supply Range an internal reference (1.182V ±1% for LTC1443 or 1.221V Single: 2V to 11V ±1% for LTC1444/LTC1445), programmable hysteresis Dual: ±1V to ±5.5V (LTC1444/LTC1445) and TTL/CMOS output (LTC1443/ n Input Voltage Range Includes the Negative Supply LTC1445) that sinks and sources current (open-drain n TTL/CMOS Compatible Outputs output for LTC1444). The reference output can drive a n Propagation Delay: 12µs (Typ) (10mV Overdrive) bypass capacitor of up to 0.01µF without oscillation. n No Crowbar Current The comparators operate from a single 2V to 11V supply n 40mA Continuous Source Current or a dual ±1V to ±5.5V supply (LTC1443). Comparator n Pin Compatible Upgrades for MAX924 (LTC1443) hysteresis is easily programmable using two resistors and n Low Profile (5mm × 4mm × 0.8mm) DFN Package the HYST pin (LTC1444/LTC1445). Each comparator’s input operates from the negative supply to within 1.3V of applicaTions the positive supply. The LTC1443/LTC1445 comparator n output stage can continuously source up to 40mA. By Battery-Powered System Monitoring n eliminating the cross-conducting current that normally Threshold Detectors n happens when the comparator changes logic states, power Window Comparators n supply glitches are eliminated. Oscillator Circuits L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear The LTC1443/LTC1444/LTC1445 are available in the Technology Corporation. All other trademarks are the property of their respective owners. 16-pin SO, PDIP and DFN packages. Typical applicaTionReference Settling Test CircuitReference Settling V 3 IN 8V V+ 3.4M 5V V+ 1% TO 8V IN A+ 5 5V + 2 OUT VREF 4 IN A– – 2mV/DIV 14 HYST 1.21M R1 1% 10k LTC1445 8 REF OUT + 1.2V 144345 TA02 R2 R3 – 2ms/DIV 2.4M 430Ω V– C1 9 1.0µF 144345 TA01 144345fe 1 Document Outline Features Applications Description Absolute Maximum Ratings Typical Application Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
