Datasheet LTC1998 (Analog Devices) - 10
Description2.5µA, 1% Accurate SOT-23 Comparator and Voltage Reference for Battery Monitoring
Pages / Page12 / 10 — APPLICATIONS INFORMATION. VERSATILE OUTPUT DRIVER. VLOGIC, BATTLO (Pins …
File Format / SizePDF / 139 Kb
APPLICATIONS INFORMATION. VERSATILE OUTPUT DRIVER. VLOGIC, BATTLO (Pins 5,6). Figure 4. LTC1998 Function Plot
APPLICATIONS INFORMATION VERSATILE OUTPUT DRIVER VLOGIC, BATTLO (Pins 5,6) Figure 4 LTC1998 Function Plot
LTC1998
The calculation of the resistor values R1, R2 and R3 is
quite straightforward and similar to the procedure outlined in the previous paragraph.
Choose a value for the sum of R1 + R2 + R3 as well as the The LTC1998 uses a CMOS push-pull output stage to drive values for low battery threshold and hysteresis. the low battery output signal. This output pin (BATTLO) has a separate supply pin, (V Solve for resistor R1: LOGIC) that can be used to provide an output voltage rail matching the VDD logic of ⎛ 5V ⎞ microprocessors. The VLOGIC pin may be tied to a volt- R1= R ( 1+R2+R3) – 1 ⎝⎜ V ⎠⎟ age lower than the voltage at the BATT pin. The VLOGIC TH2 pin may also be tied to a voltage higher than VBATT via a Solve for the sum of series resistor greater than 10k. The output will then act as an open-drain device. ⎛ 5V ⎞ (R1+R ) 2 = (R1+R2+R ) 3 – 1 In a given application, if it is possible for BATTLO to be ⎝⎜ VBAT .TTh ⎠⎟ shorted to GND or a supply, a series resistor should be added to limit the short-circuit current to 5mA. then solve for R2 and R3. Example: A system needs to detect a low battery 3.25V voltage of 3V (VBATT.Th = 3V) with 250mV hysteresis PROGRAMMED HYSTERESIS (V HYSTERESIS TH2 = 3.25V). Set the value of the resistor divider THRESHOLD PROGRAMMABLE (R1 + R2 + R3) = 1M. THRESHOLD RANGE PROGRAMMED BATTERY VOLTAGE LOW BATT R1 = 539k, R1 + R2 = 667k, R2 = 128k, R3 = 333k. RECOVERS UNDER THRESHOLD REDUCED LOAD Choose the closest 1% values, that is 536k, 332k, 127k. 2.50V BATTERY Figure 4 graphically shows the function of the LTC1998 as VOLTAGE described above. VLOGIC BATTLO 1998 F04
1998fb 10
