Datasheet LMC7101 (Microchip) - 4
ManufacturerMicrochip
DescriptionLMC7101 is a 500kHz gain bandwidth amplifier designed to operate from 2.7V to 12V single-ended power supplies with guaranteed performance at supply voltages of 2.7V, 3V, 5V, and 12V
Pages / Page12 / 4 — Electrical Characteristics—DC (12V). bold. LMC7101A. LMC7101B. Symbol. …
File Format / SizePDF / 132 Kb
Electrical Characteristics—DC (12V). bold. LMC7101A. LMC7101B. Symbol. Parameter. Condition. Typ. Min. Max. Units. Note 6. 0.00. 12.0. Note 9. 11.87
Electrical Characteristics—DC (12V) bold LMC7101A LMC7101B Symbol Parameter Condition Typ Min Max Units Note 6 0.00 12.0 Note 9 11.87
LMC7101 Micrel, Inc.
V+ = +12V, V– = 0V, V = 1.5V, V = V+/2; R = 1M = 25 CM OUT L Ω; TJ °C,
bold
values indicate –40°C ≤ TJ ≤ +85°C; unless noted
LMC7101A LMC7101B Symbol Parameter Condition Typ Min Max Min Max Units
V Input Offset Voltage 0.11 6 9 mV OS TCV Input Offset Voltage Average Drift 1.0 OS µV/°C I Input Bias Current 1.0
64 64
pA B I Input Offset Current 0.5
32 32
pA OS R Input Resistance >1 T IN Ω CMRR Common-Mode Rejection Ratio 0V ≤ V CM ≤ 12V,
Note 6
82 65 65 dB
60 60
dB V Input Common-Mode Voltage input low, V+ = 12V, –0.3 –0.20 –0.20 V CM CMRR ≥ 50dB
0.00 0.00
V input high, V+ = 12V, 12.3 12.2 12.2 V CMRR ≥ 50dB
12.0 12.0
V +PSRR Positive Power Supply V+ = 5V to 12V, 82 70 65 dB Rejection Ratio V– = 0V, V = 1.5V
65 62
dB OUT –PSRR Negative Power Supply V+ = 0V, V– = –5V to 82 70 65 dB Rejection Ratio –12V, V = –1.5V
65 62
dB OUT A Large Signal Voltage Gain sourcing or sinking, 340 80 80 V/mV V R = 2k,
Note 9 40 40
V/mV L sourcing or sinking, 300 15 15 V/mV R = 600 L Ω,
Note 9 10 10
V/mV C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, V+ = 12V, 11.98 11.9 11.9 V OUT R = 2k
11.87 11.87
V L output low, V+ = 12V, 0.02 0.10 0.10 V R = 2k,
0.13 0.13
V L output high, V+ = 12V, 11.93 11.73 11.73 V R = 600 L Ω
11.65 11.65
V output low, V+ = 12V, 0.07 0.27 0.27 V R = 600 L Ω
0.35 0.35
V I Output Short Circuit Current sourcing (V = 0V) or 300 200 200 mA SC OUT sinking (V = 12V),
120 120
mA OUT
Notes 7, 8
I Supply Current V = V+/2 0.8 1.5 1.5 mA S OUT
1.71 1.71
mA LMC7101 4 February 2005
