Datasheet MIC863 (Microchip) - 4
Manufacturer | Microchip |
Description | The MIC863 is a dual low power operational amplifier in SOT23-8 package |
Pages / Page | 17 / 4 — Micrel, Inc. MIC863 Electrical Characteristics |
File Format / Size | PDF / 2.7 Mb |
V+ = +2.7V, V− = 0V, VCM = V+/2; RL = 500kΩ to V+/2; TA = 25°C, unless otherwise noted. Bold values indicate −40°C ≤ TA ≤ +85°C.
Symbol Parameter Condition Min.
−6 Input Offset Voltage
VOS −5 Differential Offset Voltage Typ. Max. Units +6
0.1 +5 mV 0.5 mV Input Offset Voltage Temperature
Coefficient 6 µV/°C IB Input Bias Current 10 pA IOS Input Offset Current 5 pA VCM Input Voltage Range CMRR > 60dB 1 1.8 V CMRR Common-Mode Rejection Ratio 0 < VCM < 1.35V 60 83 dB PSRR Power Supply Rejection Ratio Supply voltage change of 2.7V
to 3V 55 85 dB AVOL Large-Signal Voltage Gain RL = 100kΩ, VOUT = 2VPP 70 83 RL = 500kΩ, VOUT = 2VPP 78 91 GBW Gain-Bandwidth Product RL = 200kΩ, CL = 2pF, AV = 11 350 kHz PM Phase Margin RL = 200kΩ, CL = 2pF, AV = 11 65 ° BW −3dB Bandwidth AV = 1, CL = 2pF, RL = 1MΩ 600 kHz SR Slew Rate AV = 1, CL = 2pF, RL = 1MΩ,
Positive Slew Rate = 0.17V/µs 0.35 V/µs ISC Short-Circuit Output Current IS Supply Current (per Op Amp) No Load Channel-to-Channel Crosstalk Note 6 May 7, 2014 Source 4.5 6.3 Sink 4.5 6.2
3.6
−120 4 dB mA
7 µA
dB Revision 2.0
