Datasheet MIC6211 (Microchip) - 2
ManufacturerMicrochip
DescriptionThe MIC6211 op amp is a general-purpose operational amplifier, that operates from 4V to 32V, single or differential (split) supply
Pages / Page7 / 2 — Absolute Maximum Ratings. Operating Ratings. Electrical Characteristics …
File Format / SizePDF / 990 Kb
Absolute Maximum Ratings. Operating Ratings. Electrical Characteristics (Differential Supply). bold. Symbol. Parameter. Condition
Absolute Maximum Ratings Operating Ratings Electrical Characteristics (Differential Supply) bold Symbol Parameter Condition
MIC6211 Micrel, Inc.
Supply Voltage (VV+ – VV–) ... 36V or ±18V Supply Voltage ...4V to 32V Differential Input Voltage (VIN+ – VIN–) ..±36V Ambient Temperature Range .. –40°C to +85°C Input Voltage (VIN+, VIN–) ..(VV– – 0.3V) to VV+ SOT-23-5 Thermal Resistance (θJA) ..220°C/W Output Short Circuit Current Duration ...∞ (mounted to printed circuit board)
V+ = +15V, V– = –15V, VCM = 0V; RL = 2kΩ; TA = 25°C,
bold
values indicate –40°C ≤ TA ≤ +85°C, TA = TJ; unless noted
Symbol Parameter Condition Min Typ Max Units
VOS Input Offset Voltage 2 7 mV TCVOS Average Input Offset Drift
Note 1
7 µV/°C IB Input Bias Current 50 250 nA IOS Input Offset Current 8 30 nA VCM Input Voltage Range +13.5 +13.8 V –15.0 –15.3 V CMRR Common Mode Rejection Ratio VCM = +13.5V, –15.0V 65 100 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 65 110 dB AVOL Large Signal Voltage Gain VO = ±10V 25 180 V/mV VOUT Maximum Output Voltage Swing ±12.5 ±14 V BW Bandwidth 2.5 MHz SR Slew Rate 6 V/µs ISC Output Short Circuit Current Sourcing or sinking 30 50 mA IS Supply Current 1.3 2.0 mA
Electrical Characteristics (Single Supply)
V+ = +5V, V– = 0V, VCM = 0.1V; TA = 25°C,
bold
Note 1
7 µV/°C IB Input Bias Current 65 250 nA IOS Input Offset Current 8 30 nA VCM Input Voltage Range +3.5 +3.7 V 0 –0.3 V CMRR Common Mode Rejection Ratio VCM = 0V to 3.5V 45 70 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 65 105 dB AVOL Large Signal Voltage Gain VO = 1.5V to 3.5V, RL = 2k 15 170 V/mV VOUT Maximum Output Voltage Swing RL = 10k to GND +3.8 +4.0 V RL = 10k to +5V +1.0 +1.2 V ISC Output Short Circuit Current Sourcing or sinking 20 40 mA IS Supply Current 1.2 1.8 mA
General Note:
Devices are ESD protected; however, handling precautions are recommended.
Note 1:
Not production tested. MIC6211 2 April 2006
