MCP6L1 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 200uA and an offset voltage that is 1 mV (typ)
Pages / Page
36 /6 — MCP6L1/1R/2/4. Note:. 1.E-02. 10m. 1.E. -03. -04. d 100µ. itu. -05. 10µ. …
PDF / 1.5 Mb
MCP6L1/1R/2/4. Note:. 1.E-02. 10m. 1.E. -03. -04. d 100µ. itu. -05. 10µ. s (V. e 4. -06. ag lt. 1.E-07. o 3. t M 100n. t V. -08. 10n. -09. t C. -10. 100p. t, Ou u. -11. 10p
MCP6L1/1R/2/4Note: Unless otherwise indicated, TA = +25°C, VDD = +5.0V, VSS = GND, VCM = VSS, VOUT = VDD/2, VL = VDD/2, RL = 10 kto VL and CL = 60 pF. 1.E-0210m)61.EA-031m G = +2 V/V VIN ()1.Ee-045d 100µ VOUT 1.Eitu-0510µs (Vne 41.Eg-06a1µag lt1.E-07o 3t M 100nt V1.Een-0810nurr21.Eu-091n +125°C tp +85°C 1.Et C-10100p1u +25°C t, Ou u1.Ep-1110p -40°C Inp 0In1.E-121p-1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0-1 0.E+005.E-061.E-052.E-052.E-053.E-05Input Voltage (V)Time (5 µs/div)FIGURE 2-7: Measured Input Current vs. FIGURE 2-10: The MCP6L1/1R/2/4 Show Input Voltage (below VSS). No Phase Reversal. 1200300100-30t250B)(°)) A(d80-60rrenase200 Phase uh60Gain-90Pt Cifier (µpn150oplo40-120oopm Gain -L100iescer a -40°C en20-150en-Lu Qpe +25°C 50OpOp +85°C 0-180 +125°C 0-20-2100.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.51.E-0.1 1.E1+ 1.E+10 1.E+100 1.E+1k 1.E10 +k 1.1 E+00k 1.E+1M 1.E+10M01000102Frequ 03ency 04(Hz) 05 06 07Power Supply Voltage (V)FIGURE 2-8: Open-Loop Gain, Phase vs. FIGURE 2-11: Quiescent Current vs. Frequency. Power Supply Voltage. 1,00040) A 30m t ( 20n rre 10 -40°C u +25°C 1000it C +85°C (nV/Hz) +125°C -10ircu t C -20 hor -30Input Noise Voltage DensityS10-401.E-010.11.E+011.E+0101.E+01001.E+01k1.E+010k1.E+0100k0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.50123Frequency (Hz)45Power Supply Voltage (V)FIGURE 2-9: Input Noise Voltage Density FIGURE 2-12: Output Short Circuit Current vs. Frequency. vs. Power Supply Voltage. DS22135C-page 6 2009-2012 Microchip Technology Inc. Document Outline MCP6L1/1R/2/4 - 2.8 MHz, 200 μA Op Amps 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuit FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common-Mode Input Voltage at VDD = 2.7V. FIGURE 2-2: Input Offset Voltage vs. Common-Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Ambient Temperature. FIGURE 2-4: Input Common-Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L1/1R/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Power Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom to Output Current vs. Output Current. FIGURE 2-14: Small Signal, Non-Inverting Pulse Response. FIGURE 2-15: Large Signal, Non-Inverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Inputs FIGURE 4-1: Protecting the Analog Inputs. FIGURE 4-2: Unity Gain Buffer has a Limited VOUT Range. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-3: Output Resistor, RISO, Stabilizes Large Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-4: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-5: Example Guard Ring Layout. 4.7 Application Circuits FIGURE 4-6: Sallen Key Topology. FIGURE 4-7: Multiple Feedback Topology. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product Identification System Worldwide Sales and Service
