Datasheet AD7617 (Analog Devices) - 10
Description | 16-Channel DAS with 14-Bit, Bipolar Input, Dual Simultaneous Sampling ADC |
Pages / Page | 52 / 10 — Data Sheet. AD7617. CONVST. BUSY. SCLK_SETUP. DOUT_SETUP. DOUT_HOLD. … |
File Format / Size | PDF / 964 Kb |
Data Sheet. AD7617. CONVST. BUSY. SCLK_SETUP. DOUT_SETUP. DOUT_HOLD. SCLK. SCLK_HIGH. tSCLK_LOW. tSCLK_HOLD. SDOA. DB15. DB14. DB13. DB2. DB1. DB0. SDOB. SDI
Data Sheet AD7617 CONVST BUSY t t t SCLK_SETUP DOUT_SETUP DOUT_HOLD t t SCLK SCLK_HIGH tSCLK_LOW tSCLK_HOLD CS 1 2 3 14 15 16 SCLK SDOA DB15 DB14 DB13 DB2 DB1 DB0 SDOB DB15 DB14 DB13 DB2 DB1 DB0 SDI DB15 DB14 DB13 DB2 DB1 DB0
-106
t t t DIN_SETUP DIN_HOLD DOUT_3STATE
6077 1 Figure 6. Serial Timing Diagram Rev. 0 | Page 9 of 51 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Universal Timing Specifications Parallel Mode Timing Specifications Serial Mode Timing Specifications ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CONVERTER DETAILS ANALOG INPUT Analog Input Channel Selection Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter ADC TRANSFER FUNCTION INTERNAL/EXTERNAL REFERENCE SHUTDOWN MODE DIGITAL FILTER APPLICATIONS INFORMATION FUNCTIONALITY OVERVIEW POWER SUPPLIES TYPICAL CONNECTIONS DEVICE CONFIGURATION OPERATIONAL MODE INTERNAL/EXTERNAL REFERENCE DIGITAL INTERFACE HARDWARE MODE SOFTWARE MODE RESET FUNCTIONALITY PIN FUNCTION OVERVIEW DIGITAL INTERFACE CHANNEL SELECTION Hardware Mode Software Mode PARALLEL INTERFACE Reading Conversion Results Writing Register Data Reading Register Data SERIAL INTERFACE Reading Conversion Results Writing Register Data Reading Register Data SEQUENCER HARDWARE MODE SEQUENCER SOFTWARE MODE SEQUENCER BURST SEQUENCER Hardware Mode Burst Software Mode Burst DIAGNOSTICS DIAGNOSTIC CHANNELS INTERFACE SELF TEST CRC REGISTER SUMMARY ADDRESSING REGISTERS CONFIGURATION REGISTER CHANNEL REGISTER INPUT RANGE REGISTERS Input Range Register A1 Input Range Register A2 Input Range Register B1 Input Range Register B2 SEQUENCER STACK REGISTERS STATUS REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
