Datasheet ADA4312-1 (Analog Devices) - 2
DescriptionWideband, Differential, High Output Current Line Driver with Shutdown
Pages / Page13 / 2 — ADA4312-1* PRODUCT PAGE QUICK LINKS Last Content Update: 04/08/2017. …
RevisionA
File Format / SizePDF / 479 Kb
ADA4312-1* PRODUCT PAGE QUICK LINKS Last Content Update: 04/08/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADA4312-1* PRODUCT PAGE QUICK LINKS Last Content Update: 04/08/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADA4312-1 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADA4312-1 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADA4312-1 EngineerZone Discussions. • AN-1389: Recommended Rework Procedure for the Lead Frame Chip Scale Package (LFCSP)
SAMPLE AND BUY
• AN-772: A Design and Manufacturing Guide for the Lead Visit the product page to see pricing options. Frame Chip Scale Package (LFCSP)
Data Sheet TECHNICAL SUPPORT
• ADA4312-1: Wideband, Differential, High Output Current Submit a technical question or find your regional support Line Driver with Shutdown Data Sheet number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Typical Application Circuit Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuit Applications Information Feedback Resistor Selection General Operation Half-Duplex Operation Establishing VMID Bias Control and Linearity PCB Layout Thermal Management Power Supply Bypassing Evaluation Board Outline Dimensions Ordering Guide
