DatasheetsDatasheet ADA4627-1, ADA4637-1 (Analog …
Datasheet ADA4627-1, ADA4637-1 (Analog Devices)
Description | 30 V, 80 MHz, Low Noise, Low Bias Current, JFET Op Amp |
Pages / Page | 20 / 1 — 30 V, High Speed, Low Noise, Low Bias. Current, JFET Operational … |
Revision | F |
File Format / Size | PDF / 793 Kb |
30 V, High Speed, Low Noise, Low Bias. Current, JFET Operational Amplifier. Data Sheet. ADA4627-1. /ADA4637-1. FEATURES
link to page 1
30 V, High Speed, Low Noise, Low Bias Current, JFET Operational Amplifier Data Sheet ADA4627-1 /ADA4637-1 FEATURES PIN CONFIGURATIONS Low offset voltage: 200 μV maximum NULL 1 8 NC Offset drift: 1 μV/°C typical –IN 2 ADA4627-1 7 V+ Very low input bias current: 5 pA maximum +IN 3 TOP VIEW 6 OUT (Not to Scale)
1
Extended temperature range: −40°C to +125°C V– 4 5 NULL
00 9- 55
±5 V to ±15 V dual supply NC = NO CONNECT
07
ADA4627-1 GBW: 19 M Hz
Figure 1. 8-Lead SOIC_N (R-8)
ADA4637-1 GBW : 79 MHz NULL 8 NC Voltage noise: 6.1 nV/√Hz at 1 kHz 1 –IN 2 ADA4637-1 7 V+ ADA4627-1 slew r ate: 82 V/μs +IN 3 TOP VIEW 6 OUT ADA4637-1 slew r ate: 170 V/μs V– (Not to Scale) 4 5 NULL
03 1
High gain: 120 dB typical
9- 55
NC = NO CONNECT
07
High CMRR: 116 dB typical
Figure 2. 8-Lead SOIC_N (R-8)
High PSRR: 112 dB typical APPLICATIONS NC 1 8 NC –IN 2 7 V+ High impedance sensors ADA4627-1/ +IN 3 ADA4637-1 6 OUT Photodiode amplifier TOP VIEW V– 4 5 NC Precision instrumentation Phase-locked loop filters NOTES High end, professional audio 1. NC = NO CONNECT. 2. IT IS RECOMMENDED
002
DAC output amplifier THAT THE EXPOSED PAD BE CONNECTED TO V–.
07559-
ATE
Figure 3. 8-Lead LFCSP_VD (CP-8-13)
Medical GENERAL DESCRIPTION
The ADA4627-1/ADA4637-1 are wide bandwidth precision The ADA4627-1/ADA4637-1 are specified for both the amplifiers featuring low noise, very low offset, drift, and bias industrial temperature range of −25°C to +85°C and the current. The devices operate from ±5 V to ±15 V dual supply. extended industrial temperature range of −40°C to +125°C. The The ADA4627-1/ADA4637-1 provide benefits previously found ADA4627-1/ADA4637-1 are available in tiny 8-lead LFCSP and in few amplifiers. These amplifiers combine the best specifications 8-lead SOIC packages. of precision dc and high speed ac op amps. The ADA4637-1 is The ADA4627-1/ADA4637-1 are members of a growing series a decompensated version of the ADA4627-1 and is stable at a of high speed, precision op amps offered by Analog Devices, Inc. noise gain of 5 or greater. (see Table 1). With a typical offset voltage of only 70 μV, drift of less than 1 μV/°C, and noise of only 0.86 μV p-p (0.1 Hz to 10 Hz), the ADA4627-1/ADA4637-1 are suited for applications where error sources cannot be tolerated.
Table 1. High Speed Precision Op Amps Supply 5 V Low Cost 5 V 26 V Low Power 30 V Low Cost 30 V
Single AD8615 AD8651 AD8610 AD8510 ADA4627-1/ADA4637-1 Dual AD8616 AD8652 AD8620 AD8512 Quad AD8618 AD8513
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—30 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT VOLTAGE RANGE INPUT OFFSET VOLTAGE ADJUST RANGE INPUT BIAS CURRENT NOISE CONSIDERATIONS THD + N MEASUREMENTS PRINTED CIRCUIT BOARD LAYOUT, BIAS CURRENT, AND BYPASSING OUTPUT PHASE REVERSAL DECOMPENSATED OP AMPS DRIVING CAPACITIVE LOADS OUTLINE DIMENSIONS ORDERING GUIDE
