Datasheet ADA4898-1, ADA4898-2 (Analog Devices) - 3
DescriptionHigh Voltage, Low Noise, Low Distortion, Unity Gain Stable, High Speed, Dual 8-Lead Op Amp
Pages / Page20 / 3 — Data Sheet. ADA4898-1/ADA4898-2. SPECIFICATIONS ±15 V SUPPLY. Table 1. …
RevisionE
File Format / SizePDF / 433 Kb
Data Sheet. ADA4898-1/ADA4898-2. SPECIFICATIONS ±15 V SUPPLY. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet ADA4898-1/ADA4898-2 SPECIFICATIONS ±15 V SUPPLY Table 1 Parameter Conditions Min Typ Max Unit
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13
TA = 25°C, G = +1, RF = 0 Ω, RG open, RL = 1 kΩ to GND (for G > 1, RF = 100 Ω), unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth VOUT = 100 mV p-p 65 MHz VOUT = 2 V p-p 14 MHz Bandwidth for 0.1 dB Flatness G = +2, VOUT = 2 V p-p 3.3 MHz Slew Rate VOUT = 5 V step 55 V/µs Settling Time to 0.1% VOUT = 5 V step 85 ns NOISE/DISTORTION PERFORMANCE Harmonic Distortion SFDR f = 100 kHz, VOUT = 2 V p-p −116 dBc f = 500 kHz, VOUT = 2 V p-p −93 dBc f = 1 MHz, VOUT = 2 V p-p −79 dBc Input Voltage Noise f = 1 kHz 0.9 nV/√Hz Input Current Noise f = 1 kHz 2.4 pA/√Hz DC PERFORMANCE Input Offset Voltage RF = 1 kΩ, see Figure 43 20 125 µV Input Offset Voltage Drift RF = 1 kΩ, see Figure 43 1 µV/°C Input Bias Current RF = 1 kΩ, see Figure 43 −0.1 −0.4 µA Input Bias Offset Current RF = 1 kΩ, see Figure 43 0.03 0.3 µA Input Bias Current Drift RF = 1 kΩ, see Figure 43 2 nA/°C Open-Loop Gain VOUT = ±5 V 99 103 dB INPUT CHARACTERISTICS Input Resistance Differential mode 5 kΩ Common mode 30 MΩ Input Capacitance Differential mode 3.2 pF Common mode 2.5 pF Input Common-Mode Voltage Range See Figure 43 ±11 V Common-Mode Rejection Ratio VCM = ±2 V −103 −126 dB PD (POWER-DOWN) PIN (ADA4898-1) PD Input Voltages Chip powered down ≤−14 V Chip enabled ≥−13 V PD Turn On Time VOUT = 100 mV p-p 100 ns PD Turn Off Time VOUT = 100 mV p-p 20 μs Input Leakage Current PD = +VS 0.1 µA PD = −VS −0.2 µA OUTPUT CHARACTERISTICS Output Voltage Swing RL // (RF + RG) = 500 Ω, see Figure 43 −11.0 to +11.8 −11.7 to +12.1 V RL // (RF + RG) = 1 kΩ, see Figure 43 −12.5 to +12.5 −12.8 to +12.7 V Linear Output Current f = 100 kHz, SFDR = −70 dBc, RL = 150 Ω 40 mA Short-Circuit Current Sinking/sourcing 150 mA Off Isolation f = 1 MHz, PD = −VS 80 dB POWER SUPPLY Operating Range ±4.5 ±16.5 V Quiescent Current per Amplifier PD = +VS 7.9 8.7 mA PD = −VS 0.1 0.3 mA Positive Power Supply Rejection Ratio +VS = 15 V to 17 V, −VS = −15 V −98 −107 dB Negative Power Supply Rejection Ratio +VS = 15 V, −VS = −15 V to −17 V −100 −114 dB Rev. E | Page 3 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V SUPPLY ±5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION (POWER-DOWN) PIN FOR THE ADA4898-1 APPLICATIONS INFORMATION HIGHER FEEDBACK RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE CIRCUIT CONSIDERATIONS PCB LAYOUT POWER SUPPLY BYPASSING GROUNDING OUTLINE DIMENSIONS ORDERING GUIDE NOTES NOTES NOTES
