Datasheet ADA4075-2 (Analog Devices) - 9 Manufacturer Analog Devices Description Ultralow Noise Amplifier at Lower Power Pages / Page 25 / 9 — ADA4075-2. Data Sheet. VSY = ±15V. VSY = ±5V. I B. –15. –10. VCM (V). Y … Revision C File Format / Size PDF / 1.2 Mb Document Language English
ADA4075-2. Data Sheet. VSY = ±15V. VSY = ±5V. I B. –15. –10. VCM (V). Y R. PPL. V+ – VOH. E T. OL – V–. O V. 0.1. 0.001. 0.01. 100. LOAD CURRENT (mA). 2.5. 2.0
Text Version of Document ADA4075-2 Data Sheet 60 60 VSY = ±15V VSY = ±5V 50 50 40 40 ) ) A A 30 (n 30 (n I B I B 20 20 10 10 0 0 –15 –10 –5 0 5 10 15 7–4 –3 –2 –1 0 1 2 3 4 49 -04 0 2- 642VCM (V) 64VCM (V) 07 07 Figure 15. Input Bias Current vs. Input Common-Mode Voltage Figure 18. Input Bias Current vs. Input Common-Mode Voltage10 10 VSY = ±15V VSY = ±5V ) ) (V (V IL IL A A Y R Y R PPL V+ – VOH PPL V+ – VOH U SU S O O 1 1 E T E T G V G V A OL – V– A OL – V– T T L L O V VO T T U U P P T T U U O O 0.1 0.1 00.001 0.01 0.1 1 10 100 130.001 0.01 0.1 1 10 100 01 0 2- 2- 64LOAD CURRENT (mA) 64LOAD CURRENT (mA) 07 07 Figure 16. Output Voltage to Supply Rail vs. Load Current Figure 19. Output Voltage to Supply Rail vs. Load Current2.5 2.0 VSY = ±15V VSY = ±5V ) RL = 2kΩ ) V+ – VOH RL = 2kΩ (V IL IL (V A 2.0 V+ – V A OH R 1.5 Y R LY P PPL P 1.5 U SU S O O T 1.0 E T E G G V A 1.0 OL – V– T VOL – V– A L LT O O V T V T 0.5 U U P 0.5 T P T U O OU 0 0 1–50 –25 0 25 50 75 100 125 01 14–50 –25 0 25 50 75 100 125 0 2- 2- 64TEMPERATURE (°C) 64TEMPERATURE (°C) 07 07 Figure 17. Output Voltage to Supply Rail vs. Temperature Figure 20. Output Voltage to Supply Rail vs. Temperature Rev. C | Page 8 of 24 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance Power Sequencing ESD Caution Typical Performance Characteristics Applications Information Input Protection Total Harmonic Distortion Phase Reversal DAC Output Filter Balanced Line Driver Balanced Line Receiver Low Noise Parametric Equalizer Schematic Outline Dimensions Ordering Guide
