Datasheet ADA4004-1, ADA4004-2, ADA4004-4 (Analog Devices) - 4
Description1.8nV/√Hz, 36 V Precision Dual Amplifier
Pages / Page16 / 4 — ADA4004-1/ADA4004-2/ADA4004-4. Data Sheet. Table 3. Parameter. Symbol. …
RevisionH
File Format / SizePDF / 391 Kb
ADA4004-1/ADA4004-2/ADA4004-4. Data Sheet. Table 3. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
ADA4004-1/ADA4004-2/ADA4004-4 Data Sheet Table 3 Parameter Symbol Conditions Min Typ Max Unit
VSY = ±15 V, VCM = 0 V, TA = 25°C, unless otherwise specified.
Table 3. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 40 125 μV −40°C ≤ TA ≤ +125°C 270 μV Input Bias Current IB 40 90 nA −40°C ≤ TA ≤ +125°C 165 nA Input Offset Current IOS 60 nA −40°C ≤ TA ≤ +125°C 100 nA Input Voltage Range IVR −12.5 +12.5 V Common-Mode Rejection Ratio CMRR VCM = −12.5 V to +12.5 V 110 113 dB −40°C ≤ TA ≤ +125°C 100 104 dB Open-Loop Gain AVO RL = 2 kΩ, VOUT = −12.0 V to +12.0 V 500 1200 V/mV −40°C ≤ TA ≤ +125°C 250 500 V/mV Offset Voltage Drift ∆VOS/∆T −40°C ≤ TA ≤ +125°C 0.7 1 μV/°C OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 2 kΩ to ground 13.4 13.6 V −40°C ≤ TA ≤ +125°C 13.1 13.3 V Output Voltage Low VOL RL = 2 kΩ to ground −13.3 −13.2 V −40°C ≤ TA ≤ +125°C −13.25 −13.15 V Short-Circuit Limit ISC 25 mA Output Current IO VOUT = ±13.6 V ±10 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = ±5 V to ±15 V 110 118 dB −40°C ≤ TA ≤ +125°C 110 dB Supply Current per Amplifier ISY 2.2 mA −40°C ≤ TA ≤ +125°C 2.4 mA DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ to ground 2.7 V/μs Gain Bandwidth Product GBP 12 MHz Phase Margin ΦM 48 Degrees NOISE PERFORMANCE Voltage Noise en p-p f = 0.1 Hz to 10 Hz 0.15 μV p-p Voltage Noise Density en f = 1 kHz 1.8 nV/√Hz Current Noise Density in f = 10 Hz 3.5 pA/√Hz Current Noise Density in f = 200 Hz 1.2 pA/√Hz Rev. H | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
