Datasheet AD8597, AD8599 (Analog Devices) - 5
DescriptionUltralow Distortion, Ultralow Noise Op Amp (single)
Pages / Page20 / 5 — Data Sheet. AD8597/AD8599. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. …
RevisionF
File Format / SizePDF / 721 Kb
Data Sheet. AD8597/AD8599. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter. Rating. Table 5. Package Type. θJA. θJC. Unit
Data Sheet AD8597/AD8599 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Package Type θJA θJC Unit
link to page 5
Data Sheet AD8597/AD8599 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4. Parameter Rating
θJA is specified with the device soldered on a circuit board with Supply Voltage ±18 V its exposed paddle soldered to a pad (if applicable) on a 4-layer Input Voltage −V ≤ V JEDEC standard PCB with zero air flow. IN ≤ +V Differential Input Voltage1 ±1 V
Table 5.
Output Short-Circuit to GND Indefinite
Storage Temperature Range −65°C to +150°C 8-Lead LFCSP_VD (CP-8-2) 78 20 °C/W Operating Temperature Range −40°C to +125°C 8-Lead SOIC (R-8) (AD8597) 140 39 °C/W Lead Temperature Range (Soldering 60 sec) 300°C 8-Lead SOIC (R-8) (AD8599) 120 36 °C/W Junction Temperature 150°C 1 If the differential input voltage exceeds 1 V, limit the current to 5 mA.
POWER SEQUENCING
Stresses above those listed under Absolute Maximum Ratings Apply the op amp supplies simultaneously. The op amp supplies may cause permanent damage to the device. This is a stress must be stable before any input signals are applied. In any case, rating only; functional operation of the device at these or any the input current must be limited to 5 mA. other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
ESD CAUTION
device reliability. Rev. E | Page 5 of 20 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance Power Sequencing ESD Caution Typical Performance Characteristics Functional Operation Input Voltage Range Output Phase Reversal Noise and Source Impedance Considerations Outline Dimensions Ordering Guide
