Datasheet AD8646, AD8647, AD8648 (Analog Devices) - 6
Description24 MHz Rail-to-Rail Dual Amplifier with Low Power Shutdown function
Pages / Page18 / 6 — AD8646/AD8647/AD8648. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. …
RevisionF
File Format / SizePDF / 519 Kb
AD8646/AD8647/AD8648. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Rating
AD8646/AD8647/AD8648 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating
AD8646/AD8647/AD8648 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltage 6 V soldered in a circuit board for surface-mount packages. Input Voltage GND to VSY Differential Input Voltage ±6 V
Table 4. Thermal Resistance
Output Short Circuit to GND Indefinite
Package Type θJA θJC Unit
Storage Temperature Range −65°C to +150°C 8-Lead SOIC_N 125 43 °C/W Operating Temperature Range −40°C to +125°C 8-Lead MSOP 210 45 °C/W Lead Temperature (Soldering 60 sec) 300°C 10-Lead MSOP 200 44 °C/W Junction Temperature 150°C 14-Lead SOIC_N 120 36 °C/W 14-Lead TSSOP 180 35 °C/W Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
ESD CAUTION
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. F | Page 6 of 18 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY Revision History: AD8646/AD8647/AD8648 Revision History: AD8646 Revision History: AD8648 SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER-DOWN OPERATION MULTIPLEXING OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
