Datasheet ADA4000-1, ADA4000-2, ADA4000-4 (Analog Devices) - 3
DescriptionLow Cost, Precision JFET Input Operational Amplifiers
Pages / Page16 / 3 — Data Sheet. ADA4000-1/ADA4000-2/ADA4000-4. SPECIFICATIONS ELECTRICAL …
File Format / SizePDF / 585 Kb
Data Sheet. ADA4000-1/ADA4000-2/ADA4000-4. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol
Data Sheet ADA4000-1/ADA4000-2/ADA4000-4 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol
VS = ±15.0 V, VCM = VS/2 V, TA = 25°C, unless otherwise specified.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 0.2 1.70 mV −40°C ≤ TA ≤ +125°C 3.0 mV Input Bias Current IB 5 40 pA −40°C ≤ TA ≤ +85°C 170 pA −40°C ≤ TA ≤ +125°C 4.5 nA Input Offset Current IOS 2 40 pA −40°C ≤ TA ≤ +85°C 80 pA −40°C ≤ TA ≤ +125°C 500 pA Input Voltage Range IVR −11 +15 V Common-Mode Rejection Ratio CMRR −11 V ≤ VCM ≤ +15 V 80 100 dB −40°C ≤ TA ≤ +125°C 100 dB Open-Loop Gain AVO RL = 2 kΩ, VO = ±10 V 100 110 dB Offset Voltage Drift ΔVOS/ΔT −40°C ≤ TA ≤ +125°C 2 µV/°C OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 2 kΩ to ground 13.60 13.90 V −40°C ≤ TA ≤ +125°C 13.40 V Output Voltage Low VOL RL = 2 kΩ to ground −13.4 −13.0 V −40°C ≤ TA ≤ +125°C −12.80 V Short-Circuit Current ISC ±28 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±4.0 V to ±18.0 V 82 92 dB Supply Current/Amplifier ISY 1.35 1.65 mA −40°C ≤ TA ≤ +125°C 1.80 mA DYNAMIC PERFORMANCE Slew Rate SR VI = 10 V, RL = 2 kΩ 20 V/µs Gain Bandwidth Product GBP 5 MHz Phase Margin ΦM 60 Degrees NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 1 µV p-p Voltage Noise Density en f = 1 kHz 16 nV/√Hz Current Noise Density in f = 1 kHz 0.01 pA/√Hz INPUT IMPEDANCE Differential Mode (R||C)IN-DIFF 10||4 GΩ||pF Common Mode (R||C)INCM 103||5.5 GΩ||pF Rev. B | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL AND INPUT NOISE CAPACITIVE LOAD DRIVE SETTLING TIME OUTLINE DIMENSIONS ORDERING GUIDE
