Datasheet ADA4000-1, ADA4000-2, ADA4000-4 (Analog Devices) - 6
DescriptionLow Cost, Precision JFET Input Operational Amplifiers
Pages / Page16 / 6 — ADA4000-1/ADA4000-2/ADA4000-4. Data Sheet. TYPICAL PERFORMANCE …
File Format / SizePDF / 585 Kb
ADA4000-1/ADA4000-2/ADA4000-4. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±15V. VS = ±5V. A = 25°C. TA = 25°C. CM = 0V
ADA4000-1/ADA4000-2/ADA4000-4 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS VS = ±15V VS = ±5V A = 25°C TA = 25°C CM = 0V
ADA4000-1/ADA4000-2/ADA4000-4 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 50 50 VS = ±15V VS = ±5V 45 T 45 A = 25°C TA = 25°C V V 40 CM = 0V 40 CM = 0V S S R R 35 35 LIFIE 30 LIFIE P 30 P M M A 25 A 25 F F R O 20 R O 20 BE BE 15 15 NUM NUM 10 10 5 5 0 0
003
–2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0
018
–2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 OFFSET VOLTAGE (mV) OFFSET VOLTAGE (mV)
05791- 05791- Figure 7. Input Offset Voltage Distribution, VS = ±15 V Figure 10. Input Offset Voltage Distribution, VS = ±5 V
18 14 V V S = ±15V S = ±5V 16 12 14 RS RS 10 IE 12 IE IF IF L L P P 8 10 AM AM F F 8 6 R O R O BE 6 BE 4 NUM NUM 4 2 2 0 0
004 019
0 2 4 6 8 10 12 14 16 18 20 0 2 4 6 8 10 12 14 16 18 20 TCV TCV OS (µV/°C) OS (µV/°C)
05791- 05791- Figure 8. Offset Voltage Drift Distribution, VS = ±15 V Figure 11. Offset Voltage Drift Distribution, VS = ±5 V
80 180 80 180 V V S = ±15V S = ±5V T T A = 25°C A = 25°C C C L = 35pF L = 35pF 60 135 60 135 rees) rees) 40 90 Deg 40 90 Deg B) B) d IN ( d IN ( N ( N ( AI ARG AI ARG G G 20 45 M 20 45 M E E 60° 55° HAS HAS P P 0 0 0 0 –20 –45 –20 –45 1k 10k 100k 1M 10M 100M 1k 10k 100k 1M 10M 100M
010 020
FREQUENCY (Hz) FREQUENCY (Hz)
05791- 05791- Figure 9. Open-Loop Gain and Phase Margin vs. Frequency, VS = ±15 V Figure 12. Open-Loop Gain and Phase Margin vs. Frequency, VS = ±5 V Rev. B | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL AND INPUT NOISE CAPACITIVE LOAD DRIVE SETTLING TIME OUTLINE DIMENSIONS ORDERING GUIDE
