Datasheet ADTL082, ADTL084 (Analog Devices) - 3
DescriptionLow Cost JFET Input Operational Amplifier
Pages / Page12 / 3 — ADTL082/ADTL084. SPECIFICATIONS. Table 1. J Grade. A Grade. Parameter. …
File Format / SizePDF / 300 Kb
ADTL082/ADTL084. SPECIFICATIONS. Table 1. J Grade. A Grade. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
ADTL082/ADTL084 SPECIFICATIONS Table 1 J Grade A Grade Parameter Symbol Conditions Min Typ Max Unit
VCC = ±15 V, VCM = 0 V, TA = 25°C, over all grades, unless otherwise noted.
Table 1. J Grade A Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 2 9 1.5 5.5 mV 0°C ≤ TA ≤ +70°C 10 8 mV −40°C ≤ TA ≤ +125°C 9 mV Offset Voltage Drift ΔVOS/ΔT 0°C ≤ TA ≤ +70°C 15 μV/°C −40°C ≤ TA ≤ +125°C 10 μV/°C Input Bias Current IB 2 100 2 100 pA 0°C ≤ TA ≤ +70°C 3 3 nA −40°C ≤ TA ≤ +125°C 5 nA Input Offset Current IOS 2 100 2 100 pA 0°C ≤ TA ≤ 70°C 3 3 nA −40°C ≤ TA ≤ +125°C 5 nA Input Voltage Range VCM −11 +15 −11 +15 V Common-Mode Rejection Ratio CMRR VCM = −11 V to +15 V 80 86 80 86 dB Input Impedance RIN 1012 1012 Ω Large Signal Voltage Gain AVO RL = 2 kΩ, 100 200 100 200 V/mV VO = −10 V to +10 V 0°C ≤ TA ≤ 70°C 90 200 90 200 V/mV −40°C ≤ TA ≤ +125°C 50 200 V/mV OUTPUT CHARACTERISTICS Maximum Output Voltage Swing VO RL = 10 kΩ ±12 ±13.5 ±13 ±13.5 V 0°C ≤ TA ≤ +70°C ±12 ±13 V −40°C ≤ TA ≤ +125°C ±13 V RL = 2 kΩ ±12.5 ±13.3 V 0°C ≤ TA ≤ +70°C ±10 ±12 V −40°C ≤ TA ≤ +125°C ±12 V Short-Circuit Output Current ISC ±27 ±27 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VDD = 8 V to 36 V 80 86 80 86 dB Supply Current per Amplifier ISY 1.2 1.8 1.2 1.8 mA 0°C ≤ TA ≤ +70°C 1.9 1.9 mA −40°C ≤ TA ≤ +125°C 2.0 mA DYNAMIC PERFORMANCE Slew Rate SR 20 20 V/μs Gain Bandwidth Product GBP 5 5 MHz Phase Margin φM 63 63 Degrees Total Harmonic Distortion THD VIN = 6 V rms, f = 1 kHz, 0.001 0.001 % AV = +1, RL = 2 kΩ Channel Separation CS f = 10 kHz 120 120 dB NOISE PERFORMANCE Voltage Noise Density en f = 1 kHz 16 16 nV/√Hz Rev. B | Page 3 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
