Datasheet AD8502, AD8504 (Analog Devices)
Description1 µA Micropower CMOS Operational Amplifier
Pages / Page16 / 1 — 1 μA Micropower CMOS. Operational Amplifiers. AD8502/AD8504. FEATURES. …
RevisionA
File Format / SizePDF / 525 Kb
1 μA Micropower CMOS. Operational Amplifiers. AD8502/AD8504. FEATURES. PIN CONFIGURATIONS. Supply current: 1 μA maximum/amplifier
Datasheet AD8502, AD8504 Analog Devices, Revision: A
1 μA Micropower CMOS Operational Amplifiers AD8502/AD8504 FEATURES PIN CONFIGURATIONS Supply current: 1 μA maximum/amplifier OUT A 1 8 V+ Offset voltage: 3 mV maximum –IN A 2 AD8502 7 OUT B Single-supply or dual-supply operation TOP VIEW +IN A 3 6 –IN B Rail-to-rail input and output (Not to Scale)
01 0
No phase reversal V– 4 5 +IN B
3- 32 06
Unity gain stable
Figure 1. 8-Lead SOT-23
APPLICATIONS OUT A 1 14 OUT D 2 Portable equipment –IN A 13 –IN D +IN A AD8504 Remote sensors 3 12 +IN D TOP VIEW Low power filters V+ 4 11 V– (Not to Scale) Threshold detectors +IN B 5 10 +IN C –IN B 6 9 Current sensing –IN C
38
OUT B 7 8 OUT C
0 3- 32 06 Figure 2. 14-Lead TSSOP (RU-14)
GENERAL DESCRIPTION
The AD8502/AD8504 are low power, precision CMOS operational without creating excessively large output offset errors. The amplifiers featuring a maximum supply current of 1 μA per AD8502 and AD8504 offer an additional benefit by providing amplifier. The AD8502/AD8504 have a maximum offset voltage high accuracy without the need for system calibration. of 3 mV and a typical input bias current of 1 pA operating rail- The AD8502/AD8504 are fully specified over the industrial to-rail on both the input and output. The AD8502/AD8504 can temperature range (−40°C to +85°C) and the extended indus- operate from a single-supply voltage of +1.8 V to +5.5 V or a trial temperature range (−40°C to +125°C). The AD8502 is dual-supply voltage of ±0.9 V to ±2.75 V. available in an 8-lead, SOT-23 surface-mount package. The With its low power consumption, low input bias current, and AD8504 is available in a 14-lead TSSOP surface-mount package. rail-to-rail input and output, the AD8502/AD8504 are ideally suited for a variety of battery-powered portable applications.
Table 1. Low Supply Current Op Amps
Potential applications include bedside monitors, pulse monitors,
Supply Current 1 μA 10 μA 20 μA
glucose meters, smoke and fire detectors, vibration monitors, Single AD8500 and backup battery sensors. Dual AD8502 ADA4505-2 AD8506 Quad AD8504 ADA4505-4 AD8508 The ability to swing rail-to-rail at both the input and output helps maximize dynamic range and signal-to-noise ratio in systems that operate at very low voltages. The low offset voltage allows use of the AD8502/AD8504 in systems with high gain
Rev. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2007–2009 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
