Datasheet AD8661, AD8662, AD8664 (Analog Devices) - 6
Description16 V Precision, CMOS Rail-to-Rail Quad Op Amp
Pages / Page16 / 6 — AD8661/AD8662/AD8664. Data Sheet. AD8661. ELECTRICAL …
RevisionE
File Format / SizePDF / 577 Kb
AD8661/AD8662/AD8664. Data Sheet. AD8661. ELECTRICAL CHARACTERISTICS—LFCSP ONLY. Table 4. Parameter. Symbol
AD8661/AD8662/AD8664 Data Sheet AD8661 ELECTRICAL CHARACTERISTICS—LFCSP ONLY Table 4 Parameter Symbol
VS = 16.0 V, VCM = VS/2, TA = 25°C, unless otherwise noted.
Table 4. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage V V = V /2 50 300 µV OS CM S −40°C < T < +85°C 2000 µV A Input Bias Current I 0.3 1 pA B −40°C < T < +85°C 50 pA A Input Offset Current I 0.2 0.5 pA OS −40°C < T < +85°C 20 pA A Input Voltage Range −0.1 +14.0 V Common-Mode Rejection Ratio CMRR V = −0.1 V to +14.0 V 90 110 dB CM −40°C < T < +85°C 90 110 dB A Large Signal Voltage Gain A R = 2 kΩ, V = 0.5 V to 15.5 V 200 420 V/mV VO L O Offset Voltage Drift TCV −40°C < T < +85°C 4 17 µV/°C OS A OUTPUT CHARACTERISTICS Output Voltage High V I = 1 mA 15.95 15.97 V OH L I = 10 mA 15.60 15.70 V L −40°C < T < +85°C 15.50 V A Output Voltage Low V I = 1 mA 24 50 mV OL L I = 10 mA 210 350 mV L −40°C < T < +85°C 400 mV A Short-Circuit Current I ±140 mA SC Closed-Loop Output Impedance Z f = 1 MHz, A = 1 45 Ω OUT V POWER SUPPLY Power Supply Rejection Ratio PSRR V = 5 V to 16 V 95 110 dB S −40°C < T < +85°C 95 115 dB A Supply Current per Amplifier I V = V /2 1.25 1.55 mA SY O S −40°C < T < +85°C 1.9 mA A DYNAMIC PERFORMANCE Slew Rate SR R = 2 kΩ 3.5 V/µs L Gain Bandwidth Product GBP 4 MHz Phase Margin Φ 65 Degrees O NOISE PERFORMANCE Peak-to-Peak Noise e p-p f = 0.1 Hz to 10 Hz 2.5 µV p-p n Voltage Noise Density en f = 1 kHz 12 nV/√Hz f = 10 kHz 10 nV/√Hz Current Noise Density in f = 1 kHz 0.1 pA/√Hz Rev. E | Page 6 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AD8661/AD8662/AD8664 ELECTRICAL CHARACTERISTICS—SOIC, MSOP, AND TSSOP AD8661/AD8662/AD8664 ELECTRICAL CHARACTERISTICS—SOIC, MSOP, AND TSSOP AD8661 ELECTRICAL CHARACTERISTICS—LFCSP ONLY AD8661 ELECTRICAL CHARACTERISTICS—LFCSP ONLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE NOTES
