Datasheet AD8661, AD8662, AD8664 (Analog Devices) - 9
Description16 V Precision, CMOS Rail-to-Rail Quad Op Amp
Pages / Page16 / 9 — Data Sheet. AD8661/AD8662/AD8664. 450. 140. IL = 10mA. VS = 5V AND 16V. ) …
RevisionE
File Format / SizePDF / 577 Kb
Data Sheet. AD8661/AD8662/AD8664. 450. 140. IL = 10mA. VS = 5V AND 16V. ) 400. 120. m ( 350 GE. 100. 300. DD – VOH) AT VS = 16V. OLTA V 250. TION
Data Sheet AD8661/AD8662/AD8664 450 140 IL = 10mA VS = 5V AND 16V ) 400 120 m ( 350 GE 100 300 DD – VOH) AT VS = 16V OLTA V 250 TION
Data Sheet AD8661/AD8662/AD8664 450 140 IL = 10mA VS = 5V AND 16V ) 400 V 120 m ( 350 GE (V 100 300 DD – VOH) AT VS = 16V OLTA V 250 B) 80 d V TION OL AT VS = 16V A 200 RR ( R 60 CM TU A 150 T S 40 U 100 TP OU 20 50
031 006 05200-
0
05200-
0 –40 –20 0 20 40 60 80 100 120 100 1k 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 13. Output Swing Saturation Voltage vs. Temperature, IL = 10 mA Figure 16. CMRR vs. Frequency
80 0 140 VS = 5V AND 16V VS = 5V AND 16V RL = 100kΩ 60 CL = 15pF 45 120 rees) ) 40 90 Deg 100 dB ( ( PHASE T F IN HI 20 135 B) 80 GA S d GAIN E RR ( 0 180 HAS S 60 -LOOP P P N P E O OP O –20 225 L 40 N- E P –40 270 O 20
005
–60 315
05200-
0
003
10k 100k 1M 10M 1k 10k 100k 1M 10M FREQUENCY (Hz)
05200-
FREQUENCY (Hz)
Figure 14. Open-Loop Gain and Phase Shift vs. Frequency Figure 17. PSRR vs. Frequency
1k 70 V V DD = 16V S = ±2.5 AND ±8V G = +1 60 ) RL = 100kΩ 100 % 50 AV = 100 OOT ( H S 10 R E 40 (Ω) UT AV = 1 O A L OV Z V = 10 A 30 1 IGN OS+ LL S 20 A 0.1 M OS– S 10
007 015 05200-
0.01
05200-
0 100 1k 10k 100k 1M 10M 10 100 1k FREQUENCY (Hz) LOAD CAPACITANCE (pF)
Figure 15. Closed-Loop Output Impedance vs. Frequency Figure 18. Small Signal Overshoot vs. Load Capacitance Rev. E | Page 9 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AD8661/AD8662/AD8664 ELECTRICAL CHARACTERISTICS—SOIC, MSOP, AND TSSOP AD8661/AD8662/AD8664 ELECTRICAL CHARACTERISTICS—SOIC, MSOP, AND TSSOP AD8661 ELECTRICAL CHARACTERISTICS—LFCSP ONLY AD8661 ELECTRICAL CHARACTERISTICS—LFCSP ONLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE NOTES
