Datasheet ADA4860-1 (Analog Devices) - 5
DescriptionHigh Speed, Low Cost, Op Amp
Pages / Page21 / 5 — ADA4860-1. Table 2. Parameter Conditions. Min. Typ. Max. Unit
File Format / SizePDF / 719 Kb
ADA4860-1 Table 2 Parameter Conditions Min Typ Max Unit
ADA4860-1
VS = ±5 V (@ TA = 25°C, G = +2, RL = 150 Ω, CL = 4 pF, unless otherwise noted). For G = +2, RF = RG = 499 Ω and for G = +1, RF = 550 Ω.
Table 2. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth VO = 0.2 V p-p 520 MHz VO = 2 V p-p 230 MHz VO = 0.2 V p-p, RL = 75 Ω 480 MHz G = +1, VO = 0.2 V p-p 800 MHz Bandwidth for 0.1 dB Flatness VO = 2 V p-p 125 MHz VO = 2 V p-p, RL = 75 Ω 70 MHz +Slew Rate (Rising Edge) VO = 2 V p-p 980 V/μs −Slew Rate (Falling Edge) VO = 2 V p-p 790 V/μs Settling Time to 0.5% VO = 2 V step 8 ns NOISE/DISTORTION PERFORMANCE Harmonic Distortion HD2/HD3 fC = 1 MHz, VO = 2 V p-p −90/−102 dBc fC = 5 MHz, VO = 2 V p-p −77/−94 dBc Input Voltage Noise f = 100 kHz 4.0 nV/√Hz Input Current Noise f = 100 kHz, +IN/−IN 1.5/7.7 pA/√Hz Differential Gain RL = 150 Ω 0.02 % Differential Phase RL = 150 Ω 0.02 Degrees DC PERFORMANCE Input Offset Voltage −13 −3.5 +13 mV +Input Bias Current −2 −1.0 +1 μA −Input Bias Current −7 +1.5 +10 μA Open-Loop Transresistance 400 700 kΩ INPUT CHARACTERISTICS Input Resistance +IN 12 MΩ −IN 90 Ω Input Capacitance +IN 1.5 pF Input Common-Mode Voltage Range −3.8 to +3.7 V Common-Mode Rejection Ratio VCM = ±2 V −55 −58 dB POWER DOWN PIN Input Voltage Enabled −4.4 V Power down −3.2 V Bias Current Enabled −250 nA Power down 130 μA Turn-On Time 200 ns Turn-Off Time 3.5 μs OUTPUT CHARACTERISTICS Output Overdrive Recovery Time (Rise/Fall) VIN = ±3.0 V 45/90 ns Output Voltage Swing RL = 75 Ω ±2 V RL = 150 Ω ±2.5 ±3.1 V RL = 1 kΩ ±3.9 ±4.1 V Short-Circuit Current Sinking and sourcing 85 mA POWER SUPPLY Operating Range 5 12 V Total Quiescent Current Enabled 5 6 8 mA Quiescent Current POWER DOWN pin = +VS 0.25 0.5 mA Power Supply Rejection Ratio +PSR +VS = +4 V to +6 V, −VS = −5 V −62 −64 dB −PSR +VS = +5 V, −VS = −4 V to −6 V, −58 −61 dB POWER DOWN pin = −VS Rev. 0 | Page 4 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION POWER SUPPLY BYPASSING FEEDBACK RESISTOR SELECTION DRIVING CAPACITIVE LOADS POWER DOWN PIN VIDEO AMPLIFIER SINGLE-SUPPLY OPERATION OPTIMIZING FLATNESS AND BANDWIDTH LAYOUT AND CIRCUIT BOARD PARASITICS OUTLINE DIMENSIONS ORDERING GUIDE
