Datasheet ADA4861-3 (Analog Devices) - 2
DescriptionHigh Speed, Low Cost, Triple Op-Amp
Pages / Page17 / 2 — ADA4861-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 679 Kb
ADA4861-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADA4861-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADA4861-3 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADA4861-3 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADA4861-3 EngineerZone Discussions. • ADA4861-3: High Speed, Low Cost, Triple Op Amp Data Sheet
SAMPLE AND BUY Product Highlight
Visit the product page to see pricing options. • Amplifier pricing where you want it,
User Guides TECHNICAL SUPPORT
• UG-114: Universal Evaluation Board for Triple, High Speed Submit a technical question or find your regional support Op Amps Offered in 14-Lead SOIC Packages number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• ADA4861 SPICE Macro Model Submit feedback for this data sheet.
REFERENCE MATERIALS Informational
• Advantiv™ Advanced TV Solutions
Product Selection Guide
• Amplifiers for Video Distribution • High Speed Amplifiers Selection Table
Tutorials
• MT-034: Current Feedback (CFB) Op Amps • MT-051: Current Feedback Op Amp Noise Considerations • MT-057: High Speed Current Feedback Op Amps • MT-059: Compensating for the Effects of Input Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS GAIN CONFIGURATIONS 20 MHz ACTIVE LOW-PASS FILTER RGB VIDEO DRIVER DRIVING TWO VIDEO LOADS POWER-DOWN PINS SINGLE-SUPPLY OPERATION POWER SUPPLY BYPASSING LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
