Datasheet ADA4841-1, ADA4841-2 (Analog Devices) - 10
Description | Low Power, Low Noise and Distortion, Rail-to-Rail Output Amplifier |
Pages / Page | 20 / 10 — ADA4841-1/ADA4841-2. Data Sheet. 4.5. VS = 5V. G = +2. G = +1. 4.0. S = … |
Revision | G |
File Format / Size | PDF / 676 Kb |
ADA4841-1/ADA4841-2. Data Sheet. 4.5. VS = 5V. G = +2. G = +1. 4.0. S = 5. TIME = 200ns/DIV. TIME = 100ns/DIV. VOUT. 3.5. +125°C. +25°C. 3.0. 2.5
ADA4841-1/ADA4841-2 Data Sheet 6 4.5 V VS = 5V G = +2 IN G = +1 V 4.0 S = 5 5 TIME = 200ns/DIV TIME = 100ns/DIV VOUT 3.5 4 +125°C +25°C 3.0 3 2.5 –40°C 2 2.0 1.5 1 OUTPUT VOLTAGE (V) 1.0 INPUT AND OUTPUT VOLTAGE (V) 0 0.5 –1
05614-019
0
05614-016 Figure 24. Input Overdrive Recovery Figure 27. Slew Rate vs. Temperature
6 2.0 2.0 V V IN × 2 S = 5V VS = 5V G = +2 G = +1 TIME = 100ns/DIV V 5 1.5 OUT = 2V p-p 1.5 V TIME = 100ns/DIV OUT E (V) 1.0 1.0 G A 4 V) V LT OUT O (m 0.5 0.5 (V) V 3 UT V O OUT (EXPANDED) UT UT V O IN P D V 0 0 UT 2 AND V ANDE –0.5 –0.5 IN P V AND O 1 EX UT –1.0 –1.0 INP 0 –1.5 –1.5
023 041
–1
05614-
–2.0 –2.0
05614- Figure 25. Output Overdrive Recovery Figure 28. Settling Time
1.5 6 1.2 VS =
5V +25°C V POWER DOWN PIN OUT = 2V p-p TIME = 100ns/DIV 5 1.0 1.0 G = +2 4 0.8 (V) 0.5 N –40°C +125°C PI 3 G = +1 N 0.6 W (V) 0 O UT D O 2 0.4 V ER W –0.5 OUTPUT VOLTAGE (V) PO 1 0.2 VS = 5V –1.0 0 G = +1 0
039
VIN = 1VDC TIME = 200ns/DIV –1.5
05614-022
–1
05614-
–0.2
Figure 26. Large Signal Transient Response for Various Gains Figure 29. Power-Up Time vs. Temperature Rev. G | Page 10 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER DESCRIPTION DC ERRORS NOISE CONSIDERATIONS HEADROOM CONSIDERATIONS CAPACITANCE DRIVE INPUT PROTECTION POWER-DOWN OPERATION APPLICATIONS INFORMATION TYPICAL PERFORMANCE VALUES 16-BIT ADC DRIVER RECONSTRUCTION FILTER LAYOUT CONSIDERATIONS GROUND PLANE POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
