Datasheet AD8003 (Analog Devices)
Description | Triple, 1.5 GHz Op Amp |
Pages / Page | 17 / 1 — Triple, 1.5 GHz Op Amp. Data Sheet. AD8003. FEATURES. CONNECTION DIAGRAM. … |
Revision | C |
File Format / Size | PDF / 771 Kb |
Triple, 1.5 GHz Op Amp. Data Sheet. AD8003. FEATURES. CONNECTION DIAGRAM. High speed. N 2. 1650 MHz (G = +1)
Triple, 1.5 GHz Op Amp Data Sheet AD8003 FEATURES CONNECTION DIAGRAM High speed N 2 1650 MHz (G = +1) W 730 MHz (G = +2, VO = 2 V p-p) R DO E DBACK 2 4300 V/µs (G = +2, 4 V step) S2 W E S2 O IN 2 N 2 E –V P + –I F +V Settling time 12 ns to 0.1%, 2 V step 24 23 22 21 20 19 Excellent for QXGA resolution video Gain flatness 0.1 dB to 190 MHz +VS1 1 18 +VS3 0.05% differential gain error, RL = 150 Ω FEEDBACK 1 2 17 FEEDBACK 3 0.01° differential phase error, RL = 150 Ω –IN 1 3 –IN 3 16 Low voltage offset: 0.7 mV (typical) +IN 1 +IN 3 4 15 Low input bias current: 7 µA (typical) Low noise: 1.8 nV/√Hz POWER DOWN 1 5 14 POWER DOWN 3 Low distortion over wide bandwidth: SFDR −73 dBc @ 20 MHz –VS1 6 13 –VS3 High output drive: 100 mA output load drive 7 8 9 10 11 12 Supply operation: +5 V to ±5 V voltage supply T 1 T 2 T 3 Supply current: 9.5 mA/amplifier NC NC NC OU OU OU NOTES APPLICATIONS 1. NC = NO CONNECT.
001
2. EXPOSED PAD (LFCSP ONLY): THE EXPOSED PAD CAN BE CONNECTED TO GND OR POWER PLANES, OR IT CAN BE LEFT FLOATING. High resolution video graphics
05721- Figure 1. 24-Lead, 4 mm × 4 mm LFCSP_WQ (CP-24)
Professional video Consumer video High speed instrumentation Muxing GENERAL DESCRIPTION
The AD8003 operates on only 9.5 mA of supply current per amplifier. The independent power-down function of the AD8003 The AD8003 is a triple ultrahigh speed current feedback amplifier. reduces the quiescent current even further to 1.6 mA. Using ADI’s proprietary eXtra Fast Complementary Bipolar (XFCB) process, the AD8003 achieves a bandwidth of 1.5 GHz The AD8003 amplifier is available in a compact 4 mm × 4 mm, and a slew rate of 4300 V/µs. Additional y, the amplifier provides 24-lead LFCSP_WQ. The AD8003 is rated to work over the excellent dc precision with an input bias current of 50 µA industrial temperature range of −40°C to +85°C. maximum and a dc input voltage of 0.7 mV.
3 VS = ±5V
The AD8003 has excel ent video specifications with a frequency
G = +1, R 2 F = 432Ω B) d G = +2, +5, RF = 464Ω G = +1
response that remains flat out to 190 MHz and 0.1% settling within
R G = +2 N ( 1 L = 150Ω AI VOUT = 2V p-p
12 ns to ensure that even the most demanding video systems
G 0 P
maintain excel ent fidelity. For applications that use NTSC video,
–1
as well as high speed video, the amplifier provides a differential
-LOO D E
gain of 0.05% and a differential gain of 0.01°.
–2 LOS G = +5 C –3 D
The AD8003 has very low spurious-free dynamic range (SFDR)
–4
(−73 dBc @ 20 MHz) and noise (1.8 nV/√Hz). With a supply
LIZE A M –5
range between 5 V and 11 V and ability to source 100 mA of
OR N
output current, the AD8003 is ideal for a variety of applications. 009
–6
05721-
–7 1 10 100 1000 FREQUENCY (MHz)
Figure 2. Large Signal Frequency Response for Various Gains
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2005–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Connection Diagram General Description Table of Contents Revision History Specifications with ±5 V Supply Specifications with +5 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Typical Performance Characteristics Applications Information Gain Configurations RGB Video Driver Printed Circuit Board Layout Low Distortion Pinout Signal Routing Exposed Paddle Power Supply Bypassing Grounding Outline Dimensions Ordering Guide
