DatasheetsDatasheet ADA4851-1, ADA4851-2, ADA4851-4 …
Datasheet ADA4851-1, ADA4851-2, ADA4851-4 (Analog Devices)
Description | Low Cost, High Speed, Rail-to-Rail, Output Op Amp (Dual) |
Pages / Page | 24 / 1 — Low Cost, High Speed, Rail-to-Rail,. Output Op Amps. … |
Revision | J |
File Format / Size | PDF / 412 Kb |
Low Cost, High Speed, Rail-to-Rail,. Output Op Amps. ADA4851-1/ADA4851-2/ADA4851-4. FEATURES. PIN CONFIGURATIONS
link to page 21
Low Cost, High Speed, Rail-to-Rail, Output Op Amps ADA4851-1/ADA4851-2/ADA4851-4 FEATURES PIN CONFIGURATIONS Qualified for automotive applications ADA4851-1 V 6 +V High speed OUT 1 S 130 MHz, −3 dB bandwidth –V 2 S 5 POWER DOWN 375 V/μs slew rate +IN 3 4 –IN 55 ns settling time to 0.1% TOP VIEW (Not to Scale)
05143-001
Excellent video specifications
Figure 1. ADA4851-1, 6-Lead SOT-23 (RJ-6)
0.1 dB flatness: 11 MHz Differential gain: 0.08% ADA4851-2 Differential phase: 0.09° OUT1 1 8 +VS –IN1 2 7 OUT Fully specified at +3 V, +5 V, and ±5 V supplies +IN1 3 6 –IN2 Rail-to-rail output –VS 4 5 +IN2 Output swings to within 60 mV of either rail TOP VIEW Low voltage offset: 0.6 mV (Not to Scale)
05143-058
Wide supply range: 2.7 V to 12 V
Figure 2. ADA4851-2, 8-Lead MSOP (RM-8)
Low power: 2.5 mA per amplifier Power-down mode V 1 OUT 1 14 VOUT 4 Available in space-saving packages –IN 1 2 13 –IN 4 6-lead SOT-23, 8-lead MSOP, and 14-lead TSSOP +IN 1 3 12 +IN 4 ADA4851-4 +V 4 TOP VIEW APPLICATIONS S 11 –VS (Not to Scale) +IN 2 5 10 +IN 3 Automotive infotainment systems Automotive driver assistance systems –IN 2 6 9 –IN 3 Consumer video V 7 OUT 2 8 VOUT 3 Professional video
05143-054 Figure 3. ADA4851-4, 14-Lead TSSOP (RU-14)
Video switchers Active filters Clock buffers GENERAL DESCRIPTION
The ADA4851-1 (single), ADA4851-2 (dual), and ADA4851-4 See the Automotive Products section for more details. The (quad) are low cost, high speed, voltage feedback rail-to-rail ADA4851 family is designed to work over the extended output op amps. Despite their low price, these parts provide temperature range (−40°C to +125°C). excellent overall performance and versatility. The 130 MHz,
4
−3 dB bandwidth and high slew rate make these amplifiers well
G = +1 3 VS = 5V
suited for many general-purpose, high speed applications.
RL = 1k
Ω
2 CL = 5pF
The ADA4851 family is designed to operate at supply voltages
(dB) 1
as low as +3 V and up to ±5 V. These parts provide true single-
N 0
supply capability, allowing input signals to extend 200 mV
GAI –1
below the negative rail and to within 2.2 V of the positive rail.
-LOOP D –2
On the output, the amplifiers can swing within 60 mV of either
E
supply rail.
–3 CLOS –4
With their combination of low price, excellent differential gain
–5
(0.08%), differential phase (0.09º), and 0.1 dB flatness out to 11 MHz, these amplifiers are ideal for consumer video applications.
–6 1 10 100 1k
The ADA4851-1W, ADA4851-2W, and ADA4851-4W are
FREQUENCY (MHz)
05143-004 automotive grade versions, qualified for automotive applications. Figure 4. Small-Signal Frequency Response
Rev. J Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2004–2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH +3 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY SPECIFICATIONS WITH ±5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM CONSIDERATIONS OVERLOAD BEHAVIOR AND RECOVERY Input Output SINGLE-SUPPLY VIDEO AMPLIFIER VIDEO RECONSTRUCTION FILTER OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
