Data SheetADA4850-1/ADA4850-23300VG = +2S = 3VG = +1+125CVS = 5V2RRL = 1kL = 1k250NEGATIVE SLEW RATEVOUT = 0.1V p-p+85C)1B d (200IN0/ s) VPOSITIVE SLEW RATEE ( T–1+25CA150OOP GA -LR–40C–2OSEDSLEW100L C–350–4–50110100100000.51.01.52.02.53.03.54.04.55.0FREQUENCY (MHz) 05320-057 OUTPUT VOLTAGE STEP (V) 05320-024 Figure 11. Small Signal Frequency Response for Various Temperatures Figure 14. Slew Rate vs. Output Voltage 10k3VS = 5V G = +12RL = 1k+125CV1kOUT = 0.1V p-p1B)+85Cd A)VS = 3V, 5V, ADA4850-20100–1OOP GAIN ( L+25CV10S = 3V, 5V, ADA4850-1 ENABLE–2–40CSUPPLY CURRENT (CLOSED-–3VS = 3V, 5V, ADA4850-1 POWER DOWN1–4–50.1110100100000.51.01.52.02.53.03.54.04.55.0FREQUENCY (MHz) 05320-098 POWER-DOWN VOLTAGE (V) 05320-036 Figure 12. Small Signal Frequency Response for Various Temperatures Figure 15. Supply Current vs. Power-Down Voltage 1400–40VG = +2S = 5VVS = 5V120–30R–50L = 150VOUT = 2V p-p100–60B) degrees)PHASE–6080D–90VOUT2 TO VOUT1SE ( A60–120ALK (dB)–70TOOP GAIN (SL40–150OOP PHGAIN-LCROS–80OPEN-VOUT1 TO VOUT220–180OPEN–900–210–20–240–100101001k10k100k1M10M100M1G100k1M10M100MFREQUENCY (Hz)FREQUENCY (Hz) 05320-012 05320-037 Figure 13. Open-Loop Gain and Phase vs. Frequency Figure 16. Crosstalk vs. Frequency Rev. D | Page 7 of 14 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH +3 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM AND OVERDRIVE RECOVERY CONSIDERATIONS Input Output OPERATING THE ADA4850-1/ADA4850-2 ON BIPOLAR SUPPLIES POWER-DOWN PINS OUTLINE DIMENSIONS ORDERING GUIDE
