Datasheet AD8691, AD8692, AD8694 (Analog Devices) - 6
Description | Low Cost, Low Noise, CMOS Rail-to-Rail Output Quad Op Amp |
Pages / Page | 16 / 6 — AD8691/AD8692/AD8694. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | F |
File Format / Size | PDF / 317 Kb |
AD8691/AD8692/AD8694. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2500. 300. VS = 5V. VS = 5V AND 2.7V. VCM = –0.3V TO +3.9V. 250
AD8691/AD8692/AD8694 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
VS = +5 V or ±2.5 V, unless otherwise noted.
2500 300 VS = 5V VS = 5V AND 2.7V VCM = –0.3V TO +3.9V 250 2000 RS 200 IE IF L P 1500 150 A) AM p F ( I B 100 R O 1000 BE 50 NUM 500 0 0 –50 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0
003
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 100 110 120
006
VOS (mV)
04991-
TEMPERATURE (°C)
04991- Figure 5. Input Offset Voltage Distribution Figure 8. Input Bias Current vs. Temperature
30 1.0 VS = 5V AND 2.7V VCM = 2.5V 25 TA = –40°C TO +125°C 0.8 RS IE 20 mA) IF ( L NT 0.6 P AM 15 F CURRE R O Y 0.4 L BE P 10 UP NUM S 0.2 5 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0
004
0 1 2 3 4 5 6 7
007
TCVOS (µV/°C)
04991-
VS (V)
04991- Figure 6. AD8692/AD8694 Input Offset Voltage Drift Distribution Figure 9. Supply Current vs. Supply Voltage
2000 2.5 V V S = 5V S = ±2.5V AND ±1.35V 1600 T I A = 25°C SY @ ±2.5V ) 1200 2.0 V µ ( 800 ISY @ ±1.35V GE mA) ( 400 NT 1.5 OLTA 0 T V E CURRE –400 Y 1.0 L P T OFFS –800 UP U S P IN –1200 0.5 –1600 –2000 0 –0.3 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 3.0 3.3 3.6 3.9
005
–40 –20 0 20 40 60 80 100 120 140
008
COMMON-MODE VOLTAGE (V) TEMPERATURE (°C)
04991- 04991- Figure 7. Input Offset Voltage vs. Common-Mode Voltage Figure 10. Supply Current vs. Temperature Rev. F | Page 6 of 16 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Characteristics ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide Automotive Products
