Datasheet AD8628, AD8629, AD8630 (Analog Devices) - 6
DescriptionZero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifier
Pages / Page24 / 6 — AD8628/AD8629/AD8630. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. …
RevisionK
File Format / SizePDF / 430 Kb
AD8628/AD8629/AD8630. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Rating. THERMAL CHARACTERISTICS. Table 4. Package Type
AD8628/AD8629/AD8630 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating THERMAL CHARACTERISTICS Table 4 Package Type
AD8628/AD8629/AD8630 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3. Parameter Rating THERMAL CHARACTERISTICS
Supply Voltage 6 V θJA is specified for worst-case conditions, that is, θJA is specified Input Voltage GND – 0.3 V to VS + 0.3 V for the device soldered in a circuit board for surface-mount Differential Input Voltage1 ±5.0 V packages. This was measured using a standard two-layer board. Output Short-Circuit Duration to GND Indefinite Storage Temperature Range −65°C to +150°C
Table 4.
Operating Temperature Range −40°C to +125°C
Package Type θJA θJC Unit
Junction Temperature Range −65°C to +150°C 5-Lead TSOT (UJ-5) 207 61 °C/W Lead Temperature (Soldering, 60 sec) 300°C 5-Lead SOT-23 (RJ-5) 230 146 °C/W ESD AD8628 8-Lead SOIC_N (R-8) 158 43 °C/W HBM 8-Lead SOIC ±7000V 8-Lead MSOP (RM-8) 190 44 °C/W FICDM 8-Lead SOIC ±1500V 14-Lead SOIC_N (R-14) 105 43 °C/W FICDM 5-Lead TSOT ±1000V 14-Lead TSSOP (RU-14) 148 23 °C/W MM 8-Lead SOIC ±200V ESD AD8629 HBM 8-Lead SOIC ±4000V
ESD CAUTION
FICDM 8-Lead SOIC ±1000V ESD AD8630 HBM 14-Lead SOIC ±5000V FICDM 14-Lead SOIC ±1500V FICDM 14-Lead TSSOP ±1500V MM 14-Lead SOIC ±200V 1 Differential input voltage is limited to ±5 V or the supply voltage, whichever is less. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. K | Page 6 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics—VS = 5.0 V Electrical Characteristics—VS = 2.7 V Absolute Maximum Ratings Thermal Characteristics ESD Caution Typical Performance Characteristics Functional Description 1/f Noise Peak-to-Peak Noise Noise Behavior with First-Order, Low-Pass Filter Total Integrated Input-Referred Noise for First-Order Filter Input Overvoltage Protection Output Phase Reversal Overload Recovery Time Infrared Sensors Precision Current Shunt Sensor Output Amplifier for High Precision DACs Outline Dimensions Ordering Guide Automotive Products
