Datasheet AD8615, AD8616, AD8618 (Analog Devices) - 6
DescriptionPrecision 20 MHz CMOS Single RRIO Operational Amplifier
Pages / Page20 / 6 — AD8615/AD8616/AD8618. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. …
RevisionG
File Format / SizePDF / 453 Kb
AD8615/AD8616/AD8618. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2200. 350. 2000. VS = 5V. VS = ±2.5V. TA = 25°C. 300. 1800
AD8615/AD8616/AD8618 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 2200 350 2000 VS = 5V VS = ±2.5V TA = 25°C 300 1800
AD8615/AD8616/AD8618 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 2200 350 2000 VS = 5V VS = ±2.5V TA = 25°C 300 1800 VCM = 0V TO 5V S 1600 A) R p 250 ( 1400 NT LIFIE P 200 M 1200 A F CURRE 1000 150 R O AS 800 BE BI UT 600 100 NUM INP 400 50 200 0 0 –700 –500 –300 –100 100 300 500 700 0 25 50 75 100 125
006 009
OFFSET VOLTAGE (µV) TEMPERATURE (-°C)
04648- 04648- Figure 6. Input Offset Voltage Distribution Figure 9. Input Bias Current vs. Temperature
22 1000 VS = 5V 20 VS = ±2.5V T T A = 25°C A = –40°C TO +125°C 18 VCM = 0V S 100 16 R 14 V) LIFIE P (m M 12 A UT F O 10 10 R O – V 8 SY BE V SOURCE 6 SINK NUM 1 4 2 0 0.1 0 2 4 6 8 10 12 0.001 0.01 0.1 1 10 100
010 007
ILOAD (mA) TCV
04648-
OS (µV/°C)
04648- Figure 7. Offset Voltage Drift Distribution Figure 10. Output Voltage to Supply Rail vs. Load Current
500 120 VS = 5V V 400 T S = 5V A = 25°C V) 100 300 (m V) 10mA LOAD µ E ( 200 E AG 80 LT AG 100 LT VO O 0 T V 60 E TION A –100 UR T A 40 T OFFS –200 S U P UT IN –300 P UT 20 O –400 1mA LOAD –500 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
008
–40 –25 –10 5 20 35 50 65 80 95 110 125
011
COMMON-MODE VOLTAGE (V) TEMPERATURE (°C)
04648- 04648- Figure 8. Input Offset Voltage vs. Common-Mode Voltage Figure 11. Output Saturation Voltage vs. Temperature (200 Units, Five Wafer Lots Including Process Skews) Rev. G | Page 6 of 20 Document Outline Features Applications General Description Pin Configuration Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Overvoltage Protection Output Phase Reversal Driving Capacitive Loads Overload Recovery Time D/A Conversion Low Noise Applications High Speed Photodiode Preamplifier Active Filters Power Dissipation Power Calculations for Varying or Unknown Loads Calculating Power by Measuring Ambient Temperature and Case Temperature Calculating Power by Measuring Supply Current Outline Dimensions Ordering Guide
