Datasheet AD8615, AD8616, AD8618 (Analog Devices) - 9
DescriptionPrecision 20 MHz CMOS Single RRIO Operational Amplifier
Pages / Page20 / 9 — Data Sheet. AD8615/AD8616/AD8618. 500. VS = ±2.5V. VS = 2.7V. VIN = 2V …
RevisionG
File Format / SizePDF / 453 Kb
Data Sheet. AD8615/AD8616/AD8618. 500. VS = ±2.5V. VS = 2.7V. VIN = 2V p-p. 400. TA = 25°C. AV = 10. 300. V) µ. 200. 100. O V. F –100
Data Sheet AD8615/AD8616/AD8618 500 VS = ±2.5V VS = 2.7V VIN = 2V p-p 400 TA = 25°C AV = 10 300 V) µ 200 100 O V F –100
Data Sheet AD8615/AD8616/AD8618 500 VS = ±2.5V VS = 2.7V VIN = 2V p-p 400 TA = 25°C AV = 10 300 V) µ ) ( 200 E IV G /D A V T 100 L (2 O V GE 0 A ET T S L F –100 F VO O T –200 PU IN –300 –400 –500
24 7 0
0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7
8- 02 8-
TIME (200ns/DIV)
64 64 04
COMMON-MODE VOLTAGE (V)
04 Figure 24. Settling Time Figure 27. Input Offset Voltage vs. Common-Mode Voltage (200 Units, Five Wafer Lots Including Process Skews)
500 VS = 2.7V VS = 3.5V 400 TA = 25°C ) 300 V µ ) V 200 E ( G /DI A V T µ 100 L (1 E VO 0 T AG T SE L F –100 O F V O T –200 PU IN –300 –400 –500
5 02
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5
8 8- 02 8-
TIME (1s/DIV)
64 04
64 04 Figure 25. 0.1 Hz to 10 Hz Input Voltage Noise Figure 28. Input Offset Voltage vs. Common-Mode Voltage (200 Units, Five Wafer Lots Including Process Skews)
1400 1000 VS = 2.7V V T S = ±1.35V A = 25°C 1200 T V A = 25°C CM = 0V TO 2.7V S 100 R 1000 LIFIE V) P 800 M (m T A F OU 10 O V 600 R E SY SOURCE B V 400 SINK NUM 1 200 0 0.1
9
–700 –500 –300 –100 100 300 500 700
6
0.001 0.01 0.1 1 10
02 8- 02
I
64
OFFSET VOLTAGE (µV)
8-
LOAD (mA)
04 464 0 Figure 26. Input Offset Voltage Distribution Figure 29. Output Voltage to Supply Rail vs. Load Current Rev. G | Page 9 of 20 Document Outline Features Applications General Description Pin Configuration Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Overvoltage Protection Output Phase Reversal Driving Capacitive Loads Overload Recovery Time D/A Conversion Low Noise Applications High Speed Photodiode Preamplifier Active Filters Power Dissipation Power Calculations for Varying or Unknown Loads Calculating Power by Measuring Ambient Temperature and Case Temperature Calculating Power by Measuring Supply Current Outline Dimensions Ordering Guide
