Datasheet AD8651, AD8652 (Analog Devices) - 6
Description50 MHz, Precision Low Distortion, Low Noise CMOS Dual Op Amp
Pages / Page20 / 6 — AD8651/AD8652. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = …
RevisionD
File Format / SizePDF / 472 Kb
AD8651/AD8652. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. VS = ±2.5V. VS = 5V. VCM = 0V. RS IE. IF L P M A. (µV). F O. OSV. R BE. NUM
AD8651/AD8652 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 100 VS = ±2.5V VS = 5V VCM = 0V RS IE IF L P M A (µV) F O OSV R BE NUM
AD8651/AD8652 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 60 100 VS = ±2.5V VS = 5V VCM = 0V 50 80 RS IE 40 60 IF L P M A 30 (µV) 40 F O OSV R BE 20 20 NUM 10 0 0 –20 0
08
40 80 0 1 2 3 4 5 6
-0
200 160 120 –80 –40 120 160 200
5 01
00
COMMON-MODE VOLTAGE (V)
33 1- 0
VOS (µV)
30 03 Figure 5. Input Offset Voltage Distribution Figure 8. Input Offset Voltage vs. Common-Mode Voltage
300 500 VS = ±2.5V VS = ±2.5V VCM = 0V 200 400 A) 100 (p NT 300 (µV) 0 CURRE OS S V A 200 –100 BI UT INP 100 –200 –300 0
06 09
–50 0 50 100 150
-0
0 20 40 60 80 100 120 140
-0 01 01
TEMPERATURE (°C)
33
TEMPERATURE (°C)
33 0 0 Figure 6. Input Offset Voltage vs. Temperature Figure 9. Input Bias Current vs. Temperature
60 10 VS = ±2.5V VCM = 0V 50 TA: –40°C TO +125°C 8 ) RS A IE 40 IF (m L 6 P NT M A 30 F URRE O C R Y 4 L BE 20 P UP NUM S 2 10 0 0
7 10
0 1 2 3 4 5 6 7 8 9 10 11
-00
0 1 2 3 4 5 6
-0 01
TCV
01
OS (µV/°C) SUPPLY VOLTAGE (V)
33 33 0 0 Figure 7. TCVOS Distribution Figure 10. Supply Current vs. Supply Voltage Rev. D | Page 6 of 20 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Thermal Resistance Typical Performance Characteristics Applications Theory of Operation Rail-to-Rail Output Stage Rail-to-Rail Input Stage Input Protection Overdrive Recovery Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Settling Time THD Readings vs. Common-Mode Voltage Driving a 16-Bit ADC Outline Dimensions Ordering Guide
