Datasheet ADD8710 (Analog Devices)
Description | 10-Channel Gamma Buffer with VCOM Driver |
Pages / Page | 13 / 1 — 10-Channel Gamma Buffer with VCOM Driver. ADD8710. FEATURES. PIN … |
Revision | B |
File Format / Size | PDF / 287 Kb |
10-Channel Gamma Buffer with VCOM Driver. ADD8710. FEATURES. PIN CONFIGURATION. Single-supply operation: 4.5 V to 18 V. 28 VS
10-Channel Gamma Buffer with VCOM Driver ADD8710 FEATURES PIN CONFIGURATION Single-supply operation: 4.5 V to 18 V V 1 S 28 VS Upper/lower buffers swing to VS/GND NC 2 27 NC Gamma continuous output current: >10 mA OUT1 3 26 IN1 VCOM peak output current: 250 mA OUT2 4 25 IN2 Offset voltage: 12 mV OUT3 5 24 IN3 Slew rate: 8 V/μs OUT4 6 23 IN4 Unity gain stable with large capacitive loads OUT5 7 22 IN5 ADD8710 Supply current: 700 μA per amplifier OUT6 8 21 IN6 Compact 28-lead TSSOP OUT7 9 20 IN7 OUT8 10 19 IN8 Pb-free package OUT9 11 18 IN9 Drop-in replacement for BUF11702 OUT10 12 17 IN10 APPLICATIONS OUTCOM 13 16 INCOM GND 14 15 GND
01
TFT LCD monitor panels
-0 889
TFT LCD notebook panels NC = NO CONNECT
04 Figure 1. 28-Lead TSSOP (RU Suffix)
GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM
The ADD8710 is a low cost, 10-channel gamma buffer with a
VS ADD8710 VS
VCOM driver that operates from a single supply. The part is designed for high resolution TFT LCD panels and is built on an
NC NC
advanced, high voltage CBCMOS process. The gamma buffers have a high slew rate, minimum 10 mA
1 OUT1 IN1
output current, and a high capacitive load drive capability. The
2
V
OUT2 IN2
COM buffer is capable of delivering 250 mA of peak current and can also drive large capacitive loads. The ADD8710 offers a
OUT3 3 IN3
wide supply range and offset voltages below 12 mV. The ADD8710 is specified over the −40°C to +85°C tempera-
OUT4 4 IN4
ture range and is available in a Pb-free, 28-lead TSSOP package.
OUT5 5 IN5 OUT6 6 IN6 OUT7 7 IN7 OUT8 8 IN8 OUT9 9 IN9 OUT10 10 IN10 OUTCOM V INCOM COM
02
GND GND
0 9- 88 04 Figure 2.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2004–2007 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
