Datasheet AD8045 (Analog Devices) - 2
Description3 nV/√Hz Ultralow Distortion, High Speed Op Amp
Pages / Page26 / 2 — AD8045* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 568 Kb
AD8045* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8045* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-0993: Active Filter Evaluation Board for Analog • MT-049: Op Amp Total Output Noise Calculations for Devices, Inc., - Low Distortion Pinout Op Amps Single-Pole System • AN-402: Replacing Output Clamping Op Amps with Input • MT-050: Op Amp Total Output Noise Calculations for Clamping Amps Second-Order System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-052: Op Amp Noise Figure: Don't Be Misled Design Constraints in Low Voltage High Speed Systems • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-581: Biasing and Decoupling Op Amps in Single SFDR, MTPR Supply Applications • MT-056: High Speed Voltage Feedback Op Amps
Data Sheet
• MT-058: Effects of Feedback Capacitance on VFB and CFB • AD8045: 3 nV/√Hz Ultra Low Distortion, High Speed Op Op Amps Amp Data Sheet • MT-059: Compensating for the Effects of Input
User Guides
Capacitance on VFB and CFB Op Amps Used in Current-to- • UG-084: Evaluation Board for Single, High Speed Voltage Converters Operational Amplifiers (8-Lead, SOIC with Dedicated • MT-060: Choosing Between Voltage Feedback and Feedback Pin and Exposed Paddle) Current Feedback Op Amps • UG-919: Universal Evaluation Board for Single, 8-Lead LFCSP Operational Amplifiers
DESIGN RESOURCES
• AD8045 Material Declaration
TOOLS AND SIMULATIONS
• PCN-PDN Information • Analog Filter Wizard • Quality And Reliability • Analog Photodiode Wizard • Symbols and Footprints • Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators
DISCUSSIONS
• AD8045 SPICE Macro Model View all AD8045 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT CONFIGURATIONS WIDEBAND OPERATION THEORY OF OPERATION FREQUENCY RESPONSE DC ERRORS OUTPUT NOISE APPLICATIONS INFORMATION LOW DISTORTION PINOUT HIGH SPEED ADC DRIVER 90 MHZ ACTIVE LOW-PASS FILTER (LPF) PRINTED CIRCUIT BOARD LAYOUT SIGNAL ROUTING POWER SUPPLY BYPASSING GROUNDING EXPOSED PADDLE DRIVING CAPACITIVE LOADS OUTLINE DIMENSIONS ORDERING GUIDE
