Datasheet AD8510, AD8512, AD8513 (Analog Devices) - 6
DescriptionPrecision, Very Low Noise, Low Input Bias Current, Wide Bandwidth JFET Quad Operational Amplifier
Pages / Page20 / 6 — AD8510/AD8512/AD8513. Date Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Table …
RevisionK
File Format / SizePDF / 396 Kb
AD8510/AD8512/AD8513. Date Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. Table 4. Thermal Resistance. Parameter. Rating. Package Type. θJA
AD8510/AD8512/AD8513 Date Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Table 4 Thermal Resistance Parameter Rating Package Type θJA
AD8510/AD8512/AD8513 Date Sheet ABSOLUTE MAXIMUM RATINGS Table 3. Table 4. Thermal Resistance
1
Parameter Rating Package Type θJA θJC Unit
Supply Voltage ±18 V 8-Lead MSOP (RM) 210 45 °C/W Input Voltage ±V 8-Lead SOIC_N (R) 158 43 °C/W S Output Short-Circuit Duration to GND Observe derating curves 14-Lead SOIC_N (R) 120 36 °C/W Storage Temperature Range −65°C to +150°C 14-Lead TSSOP (RU) 180 35 °C/W Operating Temperature Range −40°C to +125°C 1 θJA is specified for worst-case conditions, that is, θJA is specified for device Junction Temperature Range −65°C to +150°C soldered in circuit board for surface-mount packages. Lead Temperature (Soldering, 10 sec) 300°C Electrostatic Discharge 2000 V
ESD CAUTION
(Human Body Model) Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. J | Page 6 of 20 Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics General Application Information Input Overvoltage Protection Output Phase Reversal Total Harmonic Distortion (THD) + Noise Total Noise Including Source Resistors Settling Time Overload Recovery Time Capacitive Load Drive Open-Loop Gain and Phase Response Precision Rectifiers I-V Conversion Applications Photodiode Circuits Signal Transmission Applications Crosstalk Outline Dimensions Ordering Guide
