Datasheet AD8027, AD8028 (Analog Devices) - 6
DescriptionLow Distortion, High Speed Rail-to-Rail Input/Output Amplifier
Pages / Page27 / 6 — AD8027/AD8028. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. …
RevisionD
File Format / SizePDF / 773 Kb
AD8027/AD8028. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
AD8027/AD8028 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
DC PERFORMANCE Input Offset Voltage DISABLE/SELECT = tristate or open, PNP active 200 800 µV AD8028W only: T to T 850 µV MIN MAX DISABLE/SELECT = high NPN active 240 900 µV AD8028W only: T to T 900 µV MIN MAX Input Offset Voltage Drift T to T 2 µV/°C MIN MAX Input Bias Current1 V = 1.5 V, NPN active 4 6 µA CM T to T 4 µA MIN MAX AD8028W only: T to T 6 µA MIN MAX V = 1.5 V, PNP active −8 −11 µA CM T to T −8 µA MIN MAX AD8028W only: T to T −11 µA MIN MAX Input Offset Current AD8028W only: T to T ±0.1 ±0.9 µA MIN MAX Open-Loop Gain V = 1 V to 2 V, AD8028W only: T to T 90 100 dB OUT MIN MAX INPUT CHARACTERISTICS Input Impedance 6 MΩ Input Capacitance 2 pF Input Common-Mode Voltage Range R = 1 kΩ −0.2 to +3.2 V L Common-Mode Rejection Ratio V = 0 V to 1.5 V 88 100 dB CM AD8028W only: T to T 78 dB MIN MAX DISABLE/SELECT PIN Selection Input Voltage Crossover Low T to T 2.0 V MIN MAX Crossover High2 Tristate < ±20 µA, T to T 1.1 to 1.3 V MIN MAX Disable Input Voltage T to T 0.4 V MIN MAX Disable Switching Speed 50% of input to <10% of final V 1150 ns OUT Enable Switching Speed 50 ns OUTPUT CHARACTERISTICS Output Overdrive Recovery Time V = −4 V to +1 V, G = −1 55/55 ns IN (Rising/Falling Edge) Output Voltage Swing AD8028W only: T to T 0.07 to 4.93 0.03 to 4.97 V MIN MAX Short-Circuit Current Sinking and sourcing 72 mA Off Isolation V = 0.2 V p-p, f = 1 MHz, IN DISABLE/SELECT = low −49 dB Capacitive Load Drive 30% overshoot 20 pF POWER SUPPLY Operating Range 2.7 12 V Quiescent Current per Amplifier 6.0 8.0 mA AD8028W only: T to T 9 mA MIN MAX Quiescent Current (Disabled) DISABLE/SELECT = low 300 420 µA AD8028W only: T to T 420 µA MIN MAX Power Supply Rejection Ratio V ± 1 V, AD8028W only: T to T 88 100 dB S MIN MAX 1 No sign or a plus sign indicates current into the pin; a minus sign indicates current out of the pin. 2 It is recommended to float the DISABLE/SELECT pin for crossover high mode. Rev. D | Page 6 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION Output Short Circuit ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION INPUT STAGE CROSSOVER SELECTION OUTPUT STAGE DC ERRORS WIDEBAND OPERATION CIRCUIT CONSIDERATIONS Balanced Input Impedances PCB Layout Grounding Power Supply Bypassing APPLICATIONS INFORMATION USING THE /DISABLE SELECT PIN DRIVING A 16-BIT ADC BAND-PASS FILTER DESIGN TOOLS AND TECHNICAL SUPPORT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
