24 /7 — AD8610/AD8620. 3.0. 1.8. S = ±13V. 1.6. 2.5. 1.4. RAI. 2.0. 1.2. UP S. …
Revision
F
PDF / 374 Kb
AD8610/AD8620. 3.0. 1.8. S = ±13V. 1.6. 2.5. 1.4. RAI. 2.0. 1.2. UP S. 1.0. 1.5. T E. CURRE. 0.8. Y L. AG T. 0.6. V UT. 0.4. 0.5. 0.2. 100. 10k. 100k. 10M. 100M
AD8610/AD86203.01.8V)S = ±13VV1.6(2.5L1.4)RAIAYmL2.0(P1.2NTUP S1.0O1.5T ECURRE0.8Y LAG TP1.0L0.6UPOSV UT0.4P0.5UT 2 09 O0.2 0 01 0- 0- 73 73 0 02 0 02 0123456789101112131001k10k100k1M10M100MSUPPLY VOLTAGE (±V)RESISTANCE LOAD (Ω) Figure 9. Supply Current vs. Supply Voltage Figure 12. Output Voltage to Supply Rail vs. Resistance Load 3.054.25VVS = ±13VS = ±5VRL = 1kΩ4.202.95) VA)H ( G(m4.15HINT2.85EEAG T4.10LCURROY2.75VL PUT4.05PUP SUT O2.654.00 0 13 01 0 0- 0- 73 73 2.55 02 3.95 02 –402585125–402585125TEMPERATURE (°C)TEMPERATURE (°C) Figure 10. Supply Current vs. Temperature Figure 13. Output Voltage High vs. Temperature 2.65–3.95VVS = ±5VS = ±5VRL = 1kΩ2.60–4.00)A)(V2.55–4.05m (LOWNTE2.50G –4.10ARRELTCUO2.45Y–4.15VLTPU PUP2.40TS–4.20U O2.35–4.25 4 11 0 01 0- 0- 73 73 2.30 02 –4.30 02 –402585125–402585125TEMPERATURE (°C)TEMPERATURE (°C) Figure 11. Supply Current vs. Temperature Figure 14. Output Voltage Low vs. Temperature Rev. F | Page 7 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION FUNCTIONAL DESCRIPTION Power Consumption Driving Large Capacitive Loads Slew Rate (Unity Gain Inverting vs. Noninverting) Input Overvoltage Protection No Phase Reversal THD Readings vs. Common-Mode Voltage Noise vs. Common-Mode Voltage Settling Time Output Current Capability Operating with Supplies Greater than ±13 V Input Offset Voltage Adjustment Programmable Gain Amplifier (PGA) High Speed Instrumentation Amplifier High Speed Filters Second-Order, Low-Pass Filter High Speed, Low Noise Differential Driver OUTLINE DIMENSIONS ORDERING GUIDE
